Game restarts when switch to another App/Game
It's likely that the OS is suspending your app when it's in the background. Maybe consider caching the current state to storage when your app loses focus? That would allow you to pick up where you left off.
https://developer.android.com/guide/components/activities/activity-lifecycle
Note: I'm not a developer so I can't actually help you implement this.
Honor 10 lite
how long before it hits 80%? how good is your cellular signal strength? if it is weak, that will drain your battery. do you use wifi? being on wifi will help with battery life. however if your wifi signal is weak, that will also drain your battery. do you play games? or watch or stream movies or videos? that will also drain your battery.
My signal strength OK not weak I do sometimes watch videos on YouTube My battery drain when when My WiFi off and My phone off
[Obsolete - Old Thread] TWRP 3.4.0-0 for Moto E 2020
I have XT2052-1 with build number QPGS30.82-105-4.
I tried this twrp from Dec.31, 2020:
https://twrp.me/motorola/motorolamotoe2020.html
I took these steps:
#adb reboot bootloader
#fastboot flash boot twrp-3.5.0_10-0-ginna.img
#fastboot boot twrp-3.5.0_10-0-ginna.img
but twrp seemed to have no screen response after loading.
This means your touch screen panel is not supported. Even if you have the same phone, some Moto E 2020s have a Focaltech panel, and the current maintainers for this device have not posted a fixed TWRP image on twrp.me which supports that panel. Do you have Telegram? If so, join the https://t.me/motoe7 group and have a chat with the current maintainers of the device. They have a OrangeFox recovery image which supports the Focaltech panel.
Snapshot Query
If gallery doesn't find them, using a file manager, navigate to your /sdcard folder and locate the Pictures folder. The location path would be /sdcard/Pictures. If you use adb you can pull them to your computer with the command
Code:
adb<add .exe for Windows> pull /sdcard/Pictures/ <on Windows .\path\to\where\you\want\them> <on Linux ./path/to/save/them>
Ordered and Received
I just received and opened the box of my new Ultra. I put it on my wireless charger and was pleased to see it start charging. If it will do as well with the case I purchased I'll be a happy man. I'll let it fully charge before messing with it. I might even wait for tomorrow to set it up. I'll have all day to play with it without any given time frame and have a full charge on both phones.
Filter
