Help Theme Store fails to update with error code -19
- By CrispyFrog
- Smartphones
- 2 Replies
Yes, there is plenty of space on the phone for the install and I have tried clearing the theme store cache, but it didn't make any difference.
ok i have a duplicate device model 2 device with the same model.I think not to install rom in other device in samsung i have already android 10 in my note 10 liteyep there is no way as of right now, and most likely will not be. your device has absolutely zero dev support.
just remember no dev=no fun.
get another device that has a better dev support
definitely get a pixel phone because to get calyx os you will need to root the phone and pixles are pretty easy to root. i believe the calyx website should have all the info on how to root it and install the custom rom.I have none. I am trying to decide if this is the right move for me. That's why I'm here to ask questions.
You can get it from this topic https://androidforums.com/threads/a...ash-3-8-with-upto-81-algorithms-17th.1306283/Hi best method is remember password by your self.
How to do this?
I created this app to use for myself, I can use it to create password for all my account using my pattern.
I just remember the pattern + hash method -> I can get my password back any time.
Example:
- My password pattern is [My secret simple key] + [Login service name]
- My hash method is SHA-256
So:
- I choose my secret is HMT so I will have some patterns is HMTFacebook, HMTAndroidForum, HMTTwitter
- I hash all of them with SHA-256 so I will get the password is:
My Facebook password: 126481d646180c2c27d76e40b5770d663a11a5789533102ed1645cae95c95ac9
My AndroidForum password: 9b7aa82591b6cbb74a29a95d8326628de3f8313ce5119c0795ba11cf4cf6b2e9
My HMTTwitter password: 5ab89e78063bbe8433cc4078add145c95afe2f06dd354d4128b7899d42d323c8
That is strong, but cannot guess. You can create this perfect sauce, but no one can find out how did you cook it.
Only for about a week then you have to be a pay member anyway.YouTube Music has both free and paid tiers. But note that, as far as I am aware, uploading your own library of music is free, and you can upload up to 100,000 songs. See also this guide: https://www.howtogeek.com/685122/how-to-upload-music-to-youtube-music/ and the aforementioned support article: https://support.google.com/youtubemusic/answer/9716522?hl=en
For local files, I personally like VLC the most. It can play almost any music or video files you throw at it. If you choose to try it out, make sure to let it index all your media on your phone when you first install it. You can also manually trigger indexing in VLC -> Audio -> the three dots in the upper right corner -> Refresh.
OK, I'm afraid I can't help with "that old error message" from Windows Photo Viewer as I've never used that app in my life. But this sort of illustrates my point that you need to explain, step-by-step, what you are doing and what doesn't work. Because what you seem to say here suggests that images you downloaded to a PC yesterday can no longer be opened by the PC, and if that is what you mean then that also means that the problem is on the PC rather than the phone. And if that isn't what you mean, then you need to say clearly what is happening.
It's a common problem with these forums: you know what you mean, and you know the context to everything you say, but we only know the words you type. So a lot of stuff that you assume or take for granted we have no way of knowing. Like in your first post you didn't mention Windows at all, so I assumed you were wanting to attach photos to emails on your phone. The first mention of Windows was in the second post, and even there it wasn't obvious that you weren't copying to the computer just as a way of compressing. But after your third post I'm wondering whether you were always wanting to send the emails from a PC and were copying the photos to there in order to attach them (in which case it might be relevant to know which email software or service you might be using). And whichever (if any) of those is correct, unless you say we can't know, and hence may be looking in the wrong place for the answer. And that's just one example, there may be many other things that are relevant but which we don't know.
One question I should have asked at the start: how large are your images? Because I'd expect an image from a 13MP phone camera (Moto E 2020) to be a few MB in size, which should not cause problems for any email service these days (e.g. my Pixel 2, 12MP camera which I keep on its maximum resolution settings, photos are typically 3-4.5 MB, with the largest being about 6.5 MB). So if you add a lot of those to an email I can see some servers rejecting it, but one or two shouldn't be an issue.
Did it work?
