WiFi calling not a feature.
Hi Hadron.
Thanks for your reply.
I'm on a sim only plan, which is pay monthly.
EE checked their end and said WiFi calling was enabled. I bought the phone specifically because LG advertise it as a WiFi calling product too.
With both companies saying they're not sure what the problem is, I'm lost for a resolution.
EE will only know that WiFi calling is enabled for your account. If you bought the phone offline they won't know about its software. So I'd say that the issue is plainly with LG: does the phone support it, and if so why can't you find the setting?
For the record, on Pixel it's in Settings > Network & Internet > Mobile Network > Advanced (under "Calling"). But settings vary between manufacturers and versions.
How to save data in external storage in csv file
Hello. I`m really apologize for maybe very simple questions for android studio. Actually I`m beginner in android studio, before that made just project like "Hello World". So, decide to make 3 objects for text view , 3 objects for edit text and just one button [![][1]][1]for saving entered characters in csv file. Searched explanation in internet but had just sample for TxT files. So I changed program code from this sample,
and finally it saving in csv file, but I think it recognized yet as txt file, as solid text without 3 objects(text view) and also it just rewriting data instead previous file. I will send you the sauce and image for csv file (desired result) below. Please help me to decide this problem.
(1)activity_main.xml
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="match_parent"
android:orientation="vertical">
<TextView
android:id="@+id/View"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:padding="3dp"
android:text="Name"
android:textSize="24sp"
android:textStyle="bold"/>
<EditText
android:id="@+id/editcsv"
android:hint="@String/edit_csv"
android:inputType="text" />
<TextView
android:id="@+id/View1"
android:text="home address"
<EditText
android:id="@+id/editcsv1"
android:hint="@String/edit_csv1"
<TextView
android:id="@+id/View2"
android:text="telephone number"
android:textStyle="bold" />
<EditText
android:id="@+id/editcsv2"
android:hint="@String/edit_csv2"
<LinearLayout
android:orientation="horizontal">
<Button
android:id="@+id/saveBtn"
android:text="@String/save_csv" />
</LinearLayout>
</LinearLayout>
(2)strings.xml:
<resources>
<string name="app_name">ExternalStorageApp</string>
<string name="save_csv">save</string>
<string name="edit_csv">Please enter your name</string>
<string name="edit_csv1">Please enter your home address</string>
<string name="edit_csv2">Please enter your telephone number</string>
<string name="View">Name</string>
<string name="View1">home address</string>
<string name="View2">telephone number</string>
</resources>
(3)MainActivity.java
import android.os.Bundle;
import android.os.Environment;
import androidx.appcompat.app.AppCompatActivity;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
import java.io.BufferedReader;
import java.io.DataInputStream;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStreamReader;
import android.app.ListActivity;
public class MainActivity extends AppCompatActivity implements View.OnClickListener {
private EditText editText, editText1, editText2;
private Button saveBtn;
private String fileName = "mFile.csv";
private String filePath = "MyFileStorage";
private File mFile;
private String mData = "";
@override
setContentView(R.layout.activity_main);
// Initilization
editText = (EditText) findViewById(R.id.editcsv);
saveBtn = (Button) findViewById(R.id.saveBtn);
saveBtn.setOnClickListener(this);
// check external storage
// and aviability for saving
if (!isAvailable() || isReadOnly()) {
// if unavailable set button as enabled
// for saving and reading
saveBtn.setEnabled(false);
} else {
// if available get files for ExternalStorage
mFile = new File(getExternalFilesDir(filePath), fileName);
// check external storage for reading
private static boolean isReadOnly() {
String storageState = Environment.getExternalStorageState();
return Environment.MEDIA_MOUNTED_READ_ONLY.equals(storageState);
// check availability for external storage
private static boolean isAvailable() {
return Environment.MEDIA_MOUNTED.equals(storageState);
// simple method for pop up windows
public void showToast(String message) {
Toast.makeText(this, message, Toast.LENGTH_SHORT).show();
@override
public void onClick(View v) {
// entered datas for mData
mData = "" ;
try {
FileOutputStream fos = new FileOutputStream(mFile);
fos.write(editText.getText().toString().getBytes());
fos.write(editText1.getText().toString().getBytes());
fos.write(editText2.getText().toString().getBytes());
fos.close();
} catch (IOException e) {
e.printStackTrace();
showToast("Files was saved");
New & Dumb User
Don't forget, that it is good practice to always first 'cler data' before you uninstall an app.
This helps to ensue that the app takes all of its files with it into Digital Heaven.
Another excellent way to save space, increase security, and tidy up your device is to use your browser instead of any social or shopping apps.
Facebook, Twitter, Amazon, etc. are all space hogs that can easily be replaced with your browser.
Just bookmark your sites right after you log in.
The next time you tap that bookmark, it will take you right to that site.
If you allow cookies on your browser, you will still be logged in.
Speaking of browsers, one that I always recommend due to its speed, simplicity, and security is Lightning Browser.
This browser can easilly take the place of any app that mearly connects you to a site.
Not only that, it is so easy to use, user friendly, and fast that you will find that you will enjoy your device more.
This browser has become the base for multiple other browsers.
This link takes you to F-Droid, where you can download the original Lightning Browser.
Lightning (Lightweight web browser) - https://f-droid.org/packages/acr.browser.lightning
Juat ask if you have any questions about how to set it up or use it.
Help Needed w/Connecting Logitech C525 Webcam to MXQ Pro
hello i bought logitech c525 webcam but beelink gt king android tv box has a very bad image I wonder how to find a driver for this webcam ..?
Drivers usually come from the manufacturer of the hardware. Suggest you contact Logitech for that. Bare in mind this is a cheap camera so its image may give a good image anyway. How well does it work when used with a computer, is it better there?
Filter
