How to clear the error in android SDK location cannot be at the file system root
While downloading the android studio i am getting tis error wht i need to do
can you be more specific? what exactly does the error say? what are you trying to do? you get this error while downloading? that seems odd. or do you get it while you are installing it? are you developing an app?
just remember the more details you give us, the better we can help.
Asset Downloads
Pretty new to Android development but in the process of porting a PC project over. Project is primarily in NDK c++. At a very high level I need to pull data files off a server and consume the data within my program. I have no need to store to the device. I'm not necessarily looking for code examples but rather just overall recommendations and guidance/best practices. On PC I use cpprestsdk to request and pull down the data then grab a pointer to the data, use it, then let it go. Any and all help appreciated.
Help mini player only works for SOME videos on Youtube??
I just talked to my cousin, which knows a lot more about android than me, and he said it's gotta be the fact that I need Youtube Premium for accessing miniplayer for certain music videos. Could this be why?
that could be it as i never had any issue with the mini player, but i do have the premium subscription
How to search subfolders?
That wouldn't be possible. You'd end up with basically one phone, one set of features and one OS, which wouldn't be competetive or give any manufacturer any incentive to build it. On the other hand, to make a mobile device robust enough to support a universal installer it would have to have 50~60 GB just for the OS and drive the cost up exponentially. But I'm sure you would still want your $50 phone.
My $50 phone has 32GB. So it wouldn't be much more. I doubt the storage is a huge fraction of the cost.
Filter
