I appreciate the suggestion but this post was from last year. You might want to check the dates to save yourself from answering very old post. I'm just trying to help since you're classified as a lurker in this group. (That means you haven't participated much in the past) We can always use another person that's willing to help, so please don't be discouraged. I'm not trying to embarrass you. We've all made mistakes, I know I still do.You may try to clear all the app datas and after that to reinstall the app.
Hi, I have the same problem, some of the applications which I moved to the SD card moves back to the internal storage. Don't understand why. More over I would like to use my SD card to the maximum but for some reason it is not possible. It is very few applications which give this possibility. I have used only 8,7GB of 64GB which I want to use more.Anyone else having issues with transferring apps to my external SD card? I can transfer them and use them, but as soon as my phone restarts, all the apps that were transferred to the SD card say they are not installed. I have tried waiting a bit and unmounting and remounting the card but nothing seems to work.
IT is different than a factory reset.
It can help you eliminate the problem. In less time too, you can google it for factory reset.
Thanks i will tryIm experience is with Samsung and not with Lg's I've read that LGUP with Uppercut may succeed where others have failed.
https://forum.xda-developers.com/t/...t-kdz-flashing-g4-g5-g6-v10-v20-more.3511295/
Make sure you have the correct firmware your you specific device. Use an Md5 sum checker to verify the validity of your downloaded firmware.
care to share? it might help othersThe phone is a Galaxy J 7. After clearing my head over night I believe I found what I want. Thanks
