what phone do you have? wipe data and cache(make sure that the data is backed up though) and then uninstall and re-install the app. if that does not work then try other messaging apps and see if the same thing is happening.qk sms doesn't vibrate when receive message.
No worries, once I sign in things are good.Yeah head over to system settings and there should be a font modifier for any type of eye sights, and for growth head to developer mode that allows you to change the font ^ _ ^
Yes it's android 10 with one ui 2.5. The screenshot is from my notification panel. I checked my device csc and it from united Arabic Emirates.
Thanks marctronixx,your response seems to suggest its specific to podbean, not the phone. the phone did its job in closing the app and removing from the background.
try a different podcast app to test if the same issue applies or ask the dev of the podbean for more info on how it works or read its instructions.
Thanks marctronixx and ocnbrze. I'm reluctant to download and open a PDF from someone I don't know. I'm going to try another podcast app.ikerry? are you an old ifruit user and have moved over to android?
if so, take a look at the user guide to get comfy with the settings.
https://androidforums.com/threads/note-20-ultra-user-guide.1327329/
good info from ocnbrze as well.
Thanks for creating channel.I created a channel for your app. Good luck and thanks for sharing.
Hello Liz,Hi
I have a nexus 10, in the past I have been able to transfer films from my pc to the tablet just by using the cable it came with. However, when I now connect the tablet to my pc it doesn't recognise it, ie if I go to window explorer it doesn't appear. (I am running xp, but I have tried it with a different cable on a computer running windows 7 and it's still not recognised). I have gone to settings, storage, menu and have ticked MTP, but still nothing. Has anybody got any other ideas as to what I do?
Thanks
Liz
