Help Edge Panels
- By NightAngel79
- Smartphones
- 21 Replies
I have the same exact problem. The option EDGE PANELS is not there. I will upload a screenshot.
Confirm you phone model? Is it plus, ultra? Also unlocked or no? US? Which carrier are you on?
Do you mean...It seems I do not have any edge panels on my phone. I'll go into display, scroll down to edge screen and click on that. Only option in there is EDGE LIGHTING. There is also suppose to be EDGE PANELS. Where the heck did it go?
Sorry you don't like it. However, to get out of it, there are a two ways.
1. Long tap the split button that was for the Recently Used App List.
2. Drag the line that splits the screen all the way up, to get the bottom half of the screen or all the way down to get the top half.
For Android, I use SD maid, which will batch delete all of your duplicate files.
For pc,
https://www.microsoft.com/en-us/p/duplicate-cleaner-free/9nblggh4rrr3?activetab=pivot:overviewtab
