"Number dialed is blocked for all customers" and thoughts on Chatr mobile
So I recently switched cell phone carriers and thought I'd try Chatr Mobile (https://www.chatrwireless.com/). They seem pretty good so far. I noticed that when I call someone and don't put the area code (ex 123-4567) it says "number dialed is blocked for all customers" but when I do include the area code (ex 1-234-567-8900), it works. I never had to before as the numbers I usually call are within the same area code as my number. Any ideas why and anyone else have the same? Anyone else in Canada with Chatr and what are your thoughts?
I tried to call 18002274825 a ten digit phone number and I got the message that the number is blocked for all customers. Thi number was to report a stolen or losr credit card. my phone crrier is CHATR. Not very reliable in my opinion. If the problem that some people had was that they needed a ten digit phone number, that is what the message shouls have said . not that the number is blocked.it seems that the programmer took a big shortcut on that one.
DOUBTS ABOUT YOUTUBE APP
But is there a way to confirm the elimination of the friends list ?
That's a different question, nothing to do with uninstalling updates to the app.
I don't know because I never used it and have no idea how it worked. But if it cannot be accessed using a web browser and even the older app versions don't show it then as far as you are concerned it is gone. Whether Google simply deleted the data or whether they keep the information about who had messaged who in their ad-targetting database ("X is interested in vintage postcards and Y messaged X on YouTube so let's send ads for vintage postcards to Y") I can't say. But if it's not available through YouTube then even if Google kept a copy somewhere else you won't be able to use it.
Best I can suggest is you go completely through your Google account data and see if there is anything in your history there. If there isn't (and I doubt there will be) then just give up on it.
Edge lighting not working after recent update
Hello guys I've bought my Note 10 plus just yesterday and also wanted a nice subtle way of receiving notifications while my screen was off so i remembered about the edge lighting and i encountered the absolutely same problem as most of you: certain apps worked only for screen on. After a little searching and playing around I found out that the problem for while the screen was off is that the edge lighting replaces the screen wake up for notifications and funny enough such feature isn't actually implemented by Samsung... So the solution was very simple, simply download this app: https://play.google.com/store/apps/details?id=de.nullgrad.glimpse
called Glimpse Notifications which will wake up your screen for notifications and then enable the Edge Lighting however you want, whether for Only while screen is off or always and whenever you receive a notification while your phone is locked and screen is off Edge Lighting will work and show your info however you styled it and with the default app colors you have set. Hope this helps you folks! Have a nice day :)
Is there a cap on albums?
16 thousand albums? You've only got so much memory Son. Where do you keep them at home?
16 thousand images in an album* not 16k albums lol.
Its about 28gb of space though so I keep it on a 64gb microsd card
How are you accessing the album? Using what app? The gallery app?
Use a file explorer app instead to access the images.
Then again, why not just use Google photos, which automatically backs them up to the cloud and you'll free up that SD card also. 16,411 images will be lost if that card fails one day...
Im just using the gallery app.
Dannydet is right. Your album is full of pictures, so I think it means a lot to you. You should save them to drive or cloud storage in case the SD card fails.
Ill do that, thank you ^-^
X locked my Samsung a20
Hey, Man I always reply late. But since you are dealing with something like I was,then you understand. Ironically it's not doing much for me besides being sicker. So I stopped and figured to live in the Now while I can. Trying chemo shots. Anyway dude,that bike you described sounds awesome. Very little knowledge of Triumph, except sister did have a 2018(I think) Triumph 1000R, but sold it and got a Maserati. Still got my 2018 Busa and 2019 GSXR 1000. Presently working on 1965 Chevy Malibu with Blown 454 crate motor blueprinted,tubbed rear end. Debating on Nos or not. Keep me informed on that awesome build your doing. And Best of Luck with the chemo. Just Remember it either gets better or worse. And I Can't Believe I just said that, cause it's exactly what one of my sister's said. Scary, I actually listed And remembered it. Take care of yourself. Best Wishes.
Accessories Best QR Code Scanner Free-Qr Code Reader & Generator
Super fast & safe QR scanner & barcode reader for Android! Scans all QR code & barcodes! Very simple & easy to use!☺
Features of QR Code Scanner & Generator Free:
★ Free QR code reader and scanner
★Fastest QR code scanner
★ Fast & Free barcode scanner
★ Free barcode reader and scanner
★Instant scan
★Also a QR code generator!
★Flashlight Supported
★QR Code Scanner Online
QR codes are everywhere! Install qrcode reader app to scan QR code or to scan barcode on the go. Barcode & QR Scanner app is the only free scanner app you will ever need.
How to use:
Just open this app & click scan button then open camera to the QR code/barcode, you can quickly & easily read the information behind the square
QRcode or barcode in a few seconds and click the generator button then generate Qr Code easily☺
I am looking for a video trim application
Hello!
I am looking for an application for trim video.
I need an application where I can enter start time and end time.
Here is an example of an application where there are arrows.
This is more precise than the standard swipe with a finger, but with several hours of movies, the arrows are not sufficient.
Anyone know an application where I can enter exactly the hour, minute and second?
Issue with wallpaper after a reboot
https://www.gsmarena.com/leeco_le_s3-8393.php
This particular model appears to include a heavy manufacturer-branded user interface:
https://www.pcmag.com/reviews/leeco-le-s3
Getting past some of LeEco's Marshmallow-based eUI could be a real problem. You might want to try using a very capable, third-party launcher like Nova:
https://play.google.com/store/apps/details?id=com.teslacoilsw.launcher&hl=en_US
but depending on how locked-down eUI is at system-level, that might not be a workable solution either.
Thanks! Changed my launcher and all is well, again.
Filter
