There is a text on the top left corner of my screen that is not going. Pls Help
This is my new phone,not even a month has passed and a text which says '(c) istock/Getty Images/Ying Yang'.
I dont know what to do.
Plz suggest what should I do?
It's a watermark in the wallpaper image, solution, change it to an image that doesn't have a watermark.
If you want that particular image without the watermark, pay Getty Images some $$$ and they'll probably sell you a non-watermarked copy.
Note 20/20 Ultra Pre-order Waiting Room
My account shows a FedEx tracking number, says a label has been created and is expected to ship tomorrow, Aug 18th, 2 day standard, so looks like I'll get it on Thursday the 20th. I've been watching comparison reviews between the Galaxy Buds Plus and Galaxy Buds Live. Think I'm gonna go with the plus once I get the $150 Samsung credit.
I went on Shop Samsung last Thurs when I got the phone, ended up ordering the Buds Plus like I had planned. Saw something somewhere that it would take 4-6 weeks to process. After I registered, I got an email that it was under review and I'd be notified within 48 hours. The next day, I got the email saying it's been approved and would ship by Aug 25th. This morning, i got an email that it shipped today via FedEx Expedited and will arrive on Wed the 26th. Great Job Samsung!
Can't move any apps to sd card
Your device will always show SD card, which is the same as phone storage...
Now that you understand this, IF YOU INSERT A EXTERNAL SD CARD, CHOOSE EXTERNAL STORAGE, OR EXTERNAL SD CARD...
I'm not understanding why you want to move apps in the first place, 32gb as is, is a good amount of storage. Here's my setup:
I'VE GOT THE SAME PHONE AS YOU. 32gb internal (also shown as SD card)....
128gb external SD card.
I keep all of my apps (only) on the internal storage....
I MOVE all of my photos, video, and documents to the external storage.
Apps really do not take up that much space in your internal storage...
Let me work for you but some people like to play games especially these days or they're using it for homeschooling and now need to have different apps that they normally wouldn't download and game apps especially visual ones take up a lot of space. I have that issue myself between photo apps and games I have to have the SD card and I have a 64GB internal memory to which I added another 64 gigabytes. My issue now is the apps that I have migrated data from external are there however the newer apps I've downloaded all seem to store on the SD card and they don't want to move back the button won't work to start the migration of data from an individual app back to internal storage nor will it now migrate data from All Storage back to the internal in my case I think I'm going to have to delete the two apps I want to transfer back to internal eject the card download the apps they'll be stored on internal and then reinstall the card
How to put a photo frame images in firebase and then select a photo in which we want to overlay.
I want to develop an application which takes a photo and then the user selects the frame and adjusts/crops the photo. The photos frames are to be uploaded manually to firebase and called in app using the Api. Lastly thr user saves the photo to the device and firebase. I dont know where to start at, what concepts or samples should I look at. I did a lot of research but couldnt find. Please help me by recommending the things I should follow and look at. Thanks in advance.
Help Firmware country restrictions
I'm late to this, but in case anyone reads this later DO NOT attempt to flash UK firmware on a US Samsung Galaxy S (or Note). Best case is that the flashing tool will recognise it is incompatible and refuse to flash it. Otherwise it will brick the phone for certain.
They may both be called "Galaxy S7", but they are completely different devices inside: different SoCs, different radio hardware, probably different cameras (same headline specs but different chips is something Samsung did a lot back then). The firmware is absolutely and utterly incompatible between the two.
Stock camera
It should appear in your app drawer, usually labeled as 'Camera'.
Even if you download another app by the same name, both should appear.
If you want the downloaded app to stop being opened all the time by other apps, then you need to clear the defaults for that app.
Settings
Apps (show all)
(whatever camera app it is)
Open by default
Clear defaults
The next time that an app opens the camera, you will be asked which camera app to use.
The time after that, you will be asked again, and then given the option to make your choice permanent (setting the default) or just once.
If you choose 'just once', then you will be asked again each time an app wants to open a camera app.
You can stop this altogether by having only one camera app enabled (ie. disable the stock camera app, or uninstall all other camera apps) on your device.
Root titanium backup resets wallpaper?
hate to surface an old thread as a newbie & just wanted to post that in 2020 Titanium Backup still resets wallpaper on my unlocked/rooted j700T1 from MetroPCS flashed w SyneXOS.
I was really looking forward to automating backups with Titanium and like others, a bit let down.
I see people using oandbackup so I'll look at this.
props to TWRP backups - got restored to last night's baseline pre-Titanium!
Filter
