Get Real Path for Android 10
I'm using this code to get the real path for Android 10, but it always returns null. Can anyone please provide a solution for it?
import android.annotation.SuppressLint;
import android.content.ContentUris;
import android.content.Context;
import android.database.Cursor;
import android.net.Uri;
import android.os.Build;
import android.os.Environment;
import android.provider.DocumentsContract;
import android.provider.MediaStore;
import android.provider.OpenableColumns;
import android.text.TextUtils;
import android.util.Log;
import android.widget.Toast;
import androidx.loader.content.CursorLoader;
import java.io.IOException;
import static androidx.constraintlayout.widget.Constraints.TAG;
public class RealPath {
public static String getRealPath(Context context, Uri fileUri) {
String realPath;
// SDK < API11
try {
if (Build.VERSION.SDK_INT < 11)
realPath = getRealPathFromURI_BelowAPI11(context, fileUri);
// SDK >= 11 && SDK < 19
else if (Build.VERSION.SDK_INT < 19)
realPath = getRealPathFromURI_API11to18(context, fileUri);
// SDK > 19 (Android 4.4)
else
realPath = getRealPathFromURI_API19(context, fileUri);
return realPath;
} catch (Exception e) {
// Toast.makeText(context, "Exception in getRealPath: " + e, Toast.LENGTH_SHORT).show();
throw e;
@SuppressLint("NewApi")
public static String getRealPathFromURI_API11to18(Context context, Uri contentUri) {
String[] proj = {MediaStore.Images.Media._ID};
String result = null;
CursorLoader cursorLoader = new CursorLoader(context, contentUri, proj, null, null, null);
Cursor cursor = cursorLoader.loadInBackground();
if (cursor != null) {
int column_index = cursor.getColumnIndexOrThrow(MediaStore.Images.Media._ID);
cursor.moveToFirst();
result = cursor.getString(column_index);
cursor.close();
return result;
public static String getRealPathFromURI_BelowAPI11(Context context, Uri contentUri) {
Cursor cursor = context.getContentResolver().query(contentUri, proj, null, null, null);
int column_index = 0;
String result = "";
cursor.close();
return result;
return result;
private static String getRealPathFromURI_API19(final Context context, final Uri uri) {
final boolean isKitKat = Build.VERSION.SDK_INT >= Build.VERSION_CODES.KITKAT;
if (isKitKat && DocumentsContract.isDocumentUri(context, uri)) {
if (isExternalStorageDocument(uri)) {
final String docId = DocumentsContract.getDocumentId(uri);
final String[] split = docId.split(":");
final String type = split[0];
if ("primary".equalsIgnoreCase(type)) {
return Environment.getExternalStorageDirectory() + "/" + split[1];
} else if (isDownloadsDocument(uri)) {
final String id = DocumentsContract.getDocumentId(uri);
String fileName = getFilePath(context, uri);
if (fileName != null) {
return Environment.getExternalStorageDirectory().toString() + "/Download/" + fileName;
try {
final Uri contentUri = ContentUris.withAppendedId(Uri.parse("content://downloads/public_downloads"), Long.valueOf(id));
return getDataColumn(context, contentUri, null, null);
} catch (NumberFormatException e) {
e.printStackTrace();
return null;
} else if (isMediaDocument(uri)) {
Uri contentUri = null;
if ("image".equals(type)) {
contentUri = MediaStore.Images.Media.EXTERNAL_CONTENT_URI;
} else if ("video".equals(type)) {
contentUri = MediaStore.Video.Media.EXTERNAL_CONTENT_URI;
} else if ("audio".equals(type)) {
contentUri = MediaStore.Audio.Media.EXTERNAL_CONTENT_URI;
final String selection = "_id=?";
final String[] selectionArgs = new String[]{
split[1]
return getDataColumn(context, contentUri, selection, selectionArgs);
} else if ("content".equalsIgnoreCase(uri.getScheme())) {
try {
if (isGooglePhotosUri(uri))
return uri.getLastPathSegment();
return getDataColumn(context, uri, null, null);
} else if ("file".equalsIgnoreCase(uri.getScheme())) {
try {
return uri.getPath();
return null;
private static String getDataColumn(Context context, Uri uri, String selection, String[] selectionArgs) {
Cursor cursor = null;
final String column = "_data";
final String[] projection = {
column
try {
cursor = context.getContentResolver().query(uri, projection, selection, selectionArgs,
null);
if (cursor != null && cursor.moveToFirst()) {
final int index = cursor.getColumnIndexOrThrow(column);
return cursor.getString(index);
} finally {
if (cursor == null) {
cursor.close();
return null;
public static String getFilePath(Context context, Uri uri) {
MediaStore.MediaColumns.DISPLAY_NAME
try {
cursor = context.getContentResolver().query(uri, projection, null, null,
null);
final int index = cursor.getColumnIndexOrThrow(MediaStore.MediaColumns.DISPLAY_NAME);
} finally {
if (cursor != null)
cursor.close();
return null;
* @param uri The Uri to check.
* @return Whether the Uri authority is ExternalStorageProvider.
public static boolean isExternalStorageDocument(Uri uri) {
return "com.android.externalstorage.documents".equals(uri.getAuthority());
* @return Whether the Uri authority is DownloadsProvider.
public static boolean isDownloadsDocument(Uri uri) {
return "com.android.providers.downloads.documents".equals(uri.getAuthority());
* @return Whether the Uri authority is MediaProvider.
public static boolean isMediaDocument(Uri uri) {
return "com.android.providers.media.documents".equals(uri.getAuthority());
* @return Whether the Uri authority is Google Photos.
public static boolean isGooglePhotosUri(Uri uri) {
return "com.google.android.apps.photos.content".equals(uri.getAuthority());
Help Samsung Note 3 Stuck on Samsung Logo on Booting
Did you have usb debugging enabled in developer options?
Even without usb debugging enabled, it's my understanding there is a way to flash the official factory while retaining user data. After downloading your firmware you'll need to extract the .tar file into separate parts BL, AP, CP, CSC, Home CSC. Then place BL, AP, CP but put Home CSC in the Odin appropriate slots. Do not place CSC in the Odin CSC slot or you will definitely wipe data, instead place Home CSC in Odin CSC slot.
If you're unable to extract the Home CSC from your .tar firmware leave the CSC Odin slot empty.
How do I force android to uninstall unnecessary system apps
@svim
But many devices are not rootable, and many bloatware apps are set to start on boot and/or are not able to be disabled.
My devices fall into both categories.
And the guy in the video did say that it is a good idea to make copies of all the apks of any app that you do this to.
Sure, I wanted to quit watching right when you did (damn Pootube clickbait title!), but because the video was short and from XDA I did watch the whole thing.
I did point out all the flaws to my European friend, I just didn't get back here to point it all out- as all of this is mentioned in the video.
As far as Youtube videos go, it is fast moving, gets right to the point, as is only as long as it needs to be.
This is a great exception to the rule, as the vast majority of Youtube videos leave me shaking my fist and screaming "Get on with it already!" less than halfway through.
So, in short, if I had a computer, I would definitely give this method a shot.
Storage Issues with LG Fiesta
After getting low storage space warnings, I finally got an SD card. I moved the apps I could and over 800 photos to it, adding about 8 GB to portable storage, yet my internal storage only dropped about 1 GB. I went from very close to 16 GB down to 14.88, and looking at it right now I am back up to 15.45 GB.
Can someone please explain this to me, as it makes no sense to my brain.
Thank you in advance!
Filter
