please check out my new encryption app Alkemi
- By RonX2
- Android Development
- 0 Replies
I started writing the encryption code in 2005 (and yes, I know, that doesn't make it good). There are two versions of the app: Android and Windows. You can encrypt on one and decrypt on the other. The apps run totally privately. They do not make changes to your computer or phone (apart from the install), they do not keep a history and do not connect to the Internet unless you instruct them to via email, messaging or sharing.
The encrypted data is in an ASCII format, which I call HEXASCII. It is discussed in detail on the web site. Being in ASCII format you can text, message, messenger, email, tweet, even print out and fax if you want. You can 'hide' your encrypted text within regular text, like with an email.
You can run Alkemi in any of 10 languages like Hindi, Arabic, Chinese (simplified and traditional), Japanese, English, French, Spanish, Russian and German.
I apologize in advance for mistranslations. They are all my own doing.
Here is an example of some text encrypted by Alkemi:
1B2A1CFF5DB98E41FB35E64DA77C0CB684C87BF12CAD93F0F705A221DF4ED9BC1FA03D84EDFF63DB2298ACF471D8A8580992ECE0DCBC6440E01A0C92EA9AC16D9F49FA755E4CA4780435DF46701B7B3989CC39AE9F00824177F07E7D9252
The apps are available on my web site:
https://alkemized.com
and also on Google Play Store and Amazon App Store.
Thanks
Thanks
Not once!
