New App: KgTv Player (Version 2.4)
- By App Update
- Apps & Games
- 0 Replies
WHAT'S NEW
- Improve performance.
- Fix bugs.
EXTRA INFO
- Fix bugs.
EXTRA INFO
- Rating: 4.4
- Installs: 10,000+
- Download Size: 9.1M
- Version: 2.4
The KgTv application is the King ♛ IPTV Players because of the new features it offers. An application is available on an advanced internal player that supports most types of broadcast and encoding. It also has the largest online logos base, which has more than 9,000 logos and is updated monthly, and it features an attractive design that is easy to use and uncomplicated.
Application features:
-- Pop-up window for an independent application that allows you to view any channel, And enjoy the same time using other applications such as Facebook and Google Chrome.
--⏰ Super speed when viewing channels and perform other tasks.
-- Quality Change System Allows you to choose the quality of the broadcast as appropriate.
-- The possibility of changing the place of and size player easily and at any time and depending on your taste.
-- Channel search system is easy and fast.
--⚠ detector errors which reveal 90% of the errors, which helps to solve problems.
--✔ Automatic verification system for links provides effort and tiring experience.
-- system tags add to the aesthetic application and it organizes the channel list It supports languages and even qualities.
-- Advanced internal player supports most types of processors.
-- support secure communication via the https protocol.
--➕ Allows you to add channel listings from a link to a file or to a text file .
--✍ Ability to edit ✎ or delete channels easily.
--♻ automatic debugger for the names of the channels.
--⛔ automatic system to remove pornographic channels works by 70%.
-- Automatic system to reconnect to the server when a defect occurs.
-- ️ fully support for Smart TV and Android Box.
-- Support system shortcut links ShorTv.
And much you can discover by yourself .
Note: The application does not contain any channels is a player only!
