Galaxy S9 calendar events disappeared on future dates
- Ask a question
- 1 Replies
Clear the cache of the calendar app. If that doesn't work clear the data.
I see. I always save items to an external card, makes it easier for backing up, recovery, etc.Thanks I appreciate it. I don't have a separate SD card, just the internal one in the phone (if it comes with one). I have seen those recovery software but it requires rooting the phone which I know nothing about
Shipped the phone back to SG and had it swapped.
I do a lot of mobile photography where I use my telephoto lens, especially for nature shots and videos:
Thanks! Will try it.on my phone? never used one.
but if i was to use one, this is it:
Malwarebytes Security: Virus Cleaner, Anti-Malware
package com.example.kucingku;
import android.app.DatePickerDialog;
import android.app.Dialog;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.MotionEvent;
import android.view.View;
import android.view.ViewGroup;
import android.widget.Button;
import android.widget.DatePicker;
import android.widget.EditText;
import android.widget.TextView;
import android.widget.Toast;
import java.util.Calendar;
import androidx.fragment.app.Fragment;
import butterknife.Unbinder;
public class customer_booking_fragment_activity extends Fragment {
Button btnDatePicker, btnTimePicker;
EditText txtDate, txtTime;
private int mYear, mMonth, mDay, mHour, mMinute;
private Unbinder unbinder;
public View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState)
View view = inflater.inflate(R.layout.customer_booking_fragment_activity, container, false);
btnDatePicker = (Button) view.findViewById(R.id.button7);
btnTimePicker = (Button) view.findViewById(R.id.button8);
txtTime = (EditText) view.findViewById(R.id.in_time);
// unbinder = ButterKnife.bind(this, view);
EditText dep_date= (EditText ) view.findViewById(R.id.in_date);
btnDatePicker.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
Toast.makeText(getActivity(),"Text!",Toast.LENGTH_SHORT).show();
// Get Current Date
// TODO Auto-generated method stub
//To show current date in the datepicker
Calendar mcurrentDate=Calendar.getInstance();
mYear=mcurrentDate.get(Calendar.YEAR);
mMonth=mcurrentDate.get(Calendar.MONTH);
mDay=mcurrentDate.get(Calendar.DAY_OF_MONTH);
DatePickerDialog mDatePicker=new DatePickerDialog(customer_booking_fragment_activity.this, new [COLOR=#ff0000]OnDateSetListener[/COLOR]() { [B][COLOR=#ff0000]//HERE IT DOES NOT RECOGNIZE[/COLOR][/B]
public void onDateSet(DatePicker datepicker, int selectedyear, int selectedmonth, int selectedday)
/* Your code to get date and time */
txtDate = (EditText) getActivity().findViewById(R.id.in_date);
//TextView tv = (TextView) getActivity().findViewById(R.id.textView);
txtDate.setText(selectedday+ "/" + selectedmonth +"/"+selectedyear);
},mYear, mMonth, mDay);
mDatePicker.getDatePicker().setCalendarViewShown(false);
mDatePicker.setTitle("Select date");
mDatePicker.show();
return view;
<?xml version="1.0" encoding="utf-8"?>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:id="@+id/rl"
android:layout_height="match_parent"
android:background="#CC99FF"
tools:context=".customer_booking_fragment_activity">
<FrameLayout
android:id="@+id/frameLayout2"
android:layout_width="447dp"
android:layout_height="226dp"
android:background="#FFFFFF"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintTop_toTopOf="@+id/guideline20">
android:layout_width="434dp"
android:layout_height="247dp">
<TextView
android:id="@+id/textView9"
android:layout_width="0dp"
android:layout_height="25dp"
android:gravity="center_vertical"
android:text="Select Cat"
android:textColor="@color/selecthitam"
android:textSize="18sp"
app:layout_constraintBottom_toTopOf="@+id/guideline29"
app:layout_constraintEnd_toStartOf="@+id/guideline17"
app:layout_constraintHorizontal_bias="0.058"
app:layout_constraintStart_toStartOf="@+id/guideline50"
app:layout_constraintTop_toTopOf="parent"
app:layout_constraintVertical_bias="0.659" />
<TextView
android:id="@+id/textView11"
android:layout_width="139dp"
android:layout_height="35dp"
android:text="Select Package"
app:layout_constraintBottom_toTopOf="@+id/guideline49"
app:layout_constraintTop_toTopOf="@+id/guideline29" />
<TextView
android:id="@+id/textView10"
android:layout_width="142dp"
android:layout_height="34dp"
android:layout_marginBottom="56dp"
android:text="Select Service"
app:layout_constraintBottom_toBottomOf="parent"
app:layout_constraintHorizontal_bias="0.0"
app:layout_constraintTop_toTopOf="@+id/guideline49"
app:layout_constraintVertical_bias="1.0" />
<androidx.constraintlayout.widget.Guideline
android:id="@+id/guideline17"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:orientation="vertical"
app:layout_constraintGuide_begin="169dp" />
<Spinner
android:id="@+id/catlist"
android:layout_height="32dp"
app:layout_constraintEnd_toStartOf="@+id/guideline56"
app:layout_constraintStart_toStartOf="@+id/guideline17"
app:layout_constraintTop_toTopOf="parent" />
android:id="@+id/guideline29"
android:orientation="horizontal"
app:layout_constraintGuide_begin="70dp" />
android:id="@+id/guideline49"
app:layout_constraintGuide_begin="142dp" />
<Spinner
android:id="@+id/servicelist"
android:layout_height="36dp"
<Spinner
android:id="@+id/spinner4"
app:layout_constraintVertical_bias="0.283" />
android:id="@+id/guideline50"
app:layout_constraintGuide_begin="27dp" />
android:id="@+id/guideline56"
app:layout_constraintGuide_begin="387dp" />
</androidx.constraintlayout.widget.ConstraintLayout>
</FrameLayout>
<FrameLayout
android:id="@+id/frameLayout"
android:layout_width="448dp"
android:layout_height="246dp"
app:layout_constraintBottom_toTopOf="@+id/buttonSubmit"
app:layout_constraintTop_toBottomOf="@+id/frameLayout2">
android:layout_width="475dp"
android:layout_height="match_parent">
<TextView
android:id="@+id/textView13"
android:layout_marginEnd="24dp"
android:layout_marginBottom="40dp"
android:text="Select Date"
app:layout_constraintBottom_toTopOf="@+id/textView14"
app:layout_constraintEnd_toStartOf="@+id/guideline18"
app:layout_constraintStart_toStartOf="@+id/guideline51" />
<TextView
android:id="@+id/textView14"
android:text="Reserve Time"
app:layout_constraintBottom_toTopOf="@+id/textView15"
<EditText
android:id="@+id/in_time"
android:layout_width="132dp"
android:layout_marginStart="8dp"
android:layout_marginBottom="36dp"
android:ems="10"
android:hint="Time"
android:inputType="textPersonName"
android:textSize="14sp"
app:layout_constraintBottom_toTopOf="@+id/radioButton"
app:layout_constraintStart_toStartOf="@+id/guideline18" />
<TextView
android:id="@+id/textView15"
android:layout_width="129dp"
android:layout_height="27dp"
android:text="Time Format"
app:layout_constraintHorizontal_bias="0.278"
android:id="@+id/guideline18"
app:layout_constraintGuide_begin="167dp" />
android:id="@+id/guideline51"
app:layout_constraintGuide_end="445dp" />
android:id="@+id/guideline57"
app:layout_constraintGuide_begin="421dp" />
<EditText
android:id="@+id/in_date"
android:layout_width="134dp"
android:layout_height="37dp"
android:layout_marginTop="36dp"
android:ems="10"
android:hint="Date"
app:layout_constraintBottom_toTopOf="@+id/in_time"
app:layout_constraintVertical_bias="0.0" />
<Button
android:id="@+id/button7"
android:layout_width="86dp"
android:layout_height="31dp"
android:background="@color/colorPrimary"
android:text="SELECT DATE"
android:textColor="@color/colorFont"
android:textSize="12sp"
app:layout_constraintBottom_toTopOf="@+id/button8"
app:layout_constraintEnd_toStartOf="@+id/guideline57"
app:layout_constraintHorizontal_bias="0.461"
app:layout_constraintStart_toEndOf="@+id/in_date"
app:layout_constraintVertical_bias="0.25" />
<Button
android:id="@+id/button8"
android:text="SELECT TIME"
app:layout_constraintBottom_toTopOf="@+id/radioButton2"
app:layout_constraintHorizontal_bias="0.482"
app:layout_constraintStart_toEndOf="@+id/in_time"
tools:ignore="MissingConstraints" />
<RadioButton
android:id="@+id/radioButton"
android:layout_height="30dp"
android:text="AM"
android:textAlignment="textStart"
app:layout_constraintEnd_toStartOf="@+id/radioButton2"
app:layout_constraintHorizontal_bias="0.21"
tools:ignore="RtlCompat" />
<RadioButton
android:id="@+id/radioButton2"
android:layout_width="133dp"
android:text="PM"
</FrameLayout>
<Button
android:id="@+id/buttonSubmit"
android:layout_width="351dp"
android:layout_height="71dp"
android:layout_marginBottom="24dp"
android:text="@string/btn_submit"
android:textSize="30sp"
app:layout_constraintEnd_toEndOf="parent"
app:layout_constraintStart_toStartOf="parent" />
android:id="@+id/guideline20"
app:layout_constraintGuide_begin="131dp" />
Quoted for truth. In fact android is completely unlike Windows in this respect: there is no Desktop folder you physically put things in, and indeed the desktops are created by an app called a launcher (so if you install more than one launcher each one, when you run it, will produce its own set of desktops with different things on them).Your homescreen is a virtual location, that you can store app icons, actual files cannot reside there. You can however, add your media player icon to the homescreen, and play from it.
well keep an eye out here. there maybe others here who might be able to help further. i'll keep looking for answers and will post anything that i come across here in this thread.
So lately while installing new apps on my OnePlus 6 I do not get any notifications from those apps. I have checked all settings but cannot find anything.
It is quite annoying since I want to install a habit tracker that reminds me of habbits. The notifications I am setting up are not coming to the phone.
Does anyone have any idea what this could be?
Thanks!
