About Memento Design Pattern
- Android Development
- 0 Replies
Can anyone explain what is the usage of take care class?
Yes... I got that, but if I screen shot what I have now you will see the option because with the current them it adds it too the list,as I said the OEM theme,skin, launcher whatever you want to call it doesn't have that option..
Issue for me began with Android update that messed up the proximity sensor. Tried a bunch of apps with no success, then found this simple workaround: when dialing number, add a "Pause" (symbolized with a comma ',') and the phone will display the screen. Changed all my contacts when I found that. Doesn't make a difference for incoming calls, but solves the issue for outgoing calls at least and makes it possible to phone in to a service where options must be selected (i.e. 'Press 1 for X, press 2 for Y...')Hey, ok so this is first time I've been really annoyed at my phone. I am trying to just hang up on someone and I can't get the screen to turn on I'm pressing every button and it flashes for a second then off.
How can I just keep the screen on during a call?
Thanks for the thought but doubtful. I'm retired. I don't do email on my phone and the only reason I'm using Outlook is that I still have a licensed copy of MS Office 2010 from my job on my PC, am generally familiar with it, and the native Win10 email and contacts programs had no manual way to back up and restore that I could figure out. The only account I have is the email address that's tied to my personal web pageIf you had them both logged into your Outlook account, then Outlook on your PC and phone will sync automatically.
My Sony Experia mobile does not work as it says "mobile network not available".
It worked OK for the last 7 years, suddenly the phone says Mem.Error, delete some files from sd or internal storage.
How do I get mobile network as it was before?
Help! I recently downloaded a hidden settings app and one of the menu options says an Activity Picker. After clicking it lists a bunch of shady options. What does this do? After clicking on one of the options it does nothing.
I am with Virgin mobile in Ontario Canada and I am able to access the internet
and where do I find out if my tablet is registered as a mobile device. ....
