Setting my S5 AT&T to WiFi Calling
Flashing a phone is mostly a labor intensive task, so that $100 fee is for labor, not the value of the update nor your phone. Whatever warranty that applies to this phone being a recent purchase is a debatable issue. If WiFi Calling is a stated or implied feature than you may or may not have some leverage to force Best Buy to cover part or all of the costs. Look through the Best Buy documentation if it actually refers to WiFi Calling as being an integral part of the phone you bought from them. If yes you can try threatening a lawsuit, if no, they have the upper hand.
Just note that it's not a hardware matter so Samsung isn't directly responsible. It's a software matter, tied to directly to the carrier but since you didn't actually purchase this phone from AT&T, it isn't liable either.
Either way, paying $100 might be your only option at this point. Hiring a lawyer to go up against either or all three of these big corporations (Samsung, AT&T, and Best Buy) will involve a lot more money given all three have seriously massive legal departments. Plus, consumer protection laws here in America are tilted towards corporate interests.
If third-party WiFi Calling options like Google Voice aren't an option for you. you initially referred to having an AT&T extender. Have you tried resetting it and making sure it's implemented in an optimal way? Those cellular extender units often require a good connection to your router (check the Ethernet cable running between the two) and just as importantly, physically locating the extender (or its external antenna if it has one) next to an outward facing window so it can receive a stable GPS signal.
How To How to disable Bixby
By default when you press and hold the side button on your Samsung Galaxy S20 Plus it will launch Bixby. You'll probably want to change the Bixby button to launch something else or disable Bixby completely. Don't worry- you can:
  • Settings > Advanced Features > Side Key
  • Find the "Press and Hold" area
  • Select "Power Off Menu" instead of "Wake Bixby (default)"
When you press and hold the side button you'll now be given power off and restart options for your Galaxy Z Flip. You cannot force the phone to launch an app by pressing and holding, but if you quickly press the side button twice you can have the Galaxy S20 Plus open any app you'd like.
(This works for any of the new generation of Galaxy phones)
How To Disable Samsung Pay quick launch
If your like me you have accidentally launch Samsung Pay several times. At first I could not figure out how I was even doing it.
(As seen in the video, I use the Pixel-esq no navigation buttons setup, where I swipe up for apps, swipe up and pause for recent programs, and swipe from left or right to 'go back'. I love this setup and can't imagine going back.)
Now, after launching Samsung pay on accident several times, I finally noticed a 'quick launch' bar/window on the bottom of screen. Then I hunted for how to disable. Hopefully this helps you as well!
Samsung link below, but: Open Samsung Pay>Top left 3 line menu>Settings>Use Favorite Cards>Toggle off Home Screen (or all of them like me)
This only disables the quick launch, app will still work.
https://www.samsung.com/us/support/troubleshooting/TSG01003274/
Help Calendar / datetime / reminder software suggestions
Auto-correct is a function of the keyboard app, though if it's smart enough to check system settings then find "languages and input" there and set your preference accordingly (mine is "English (United Kingdom)"). There's also (on my Android 10 phone) a "spell checker" setting in there, which I also set to UK English (though I suspect that's really a setting for the built-in keyboard, which I don't use).
As for setting ISO time format, I can't find anything on mine. Mind you I'm using a Pixel, and Google actually are not good at offering options and customisation - they take a "we know what you want" attitude (I sometimes think they really want to be Apple...).
Can't find setting to auto start an app when re-booting phone
See if this helps https://www.softwarert.com/app-auto-run-samsung-mobile-phone/
But if there is no built in app, you can download an app called microdroid, and in it you can configure the the app should open automatically when you turn on your phone
Yes, I had looked at that page and several others prior to posting. Will take another look; maybe I missed something there.
Thanks for the pointer to microdroid. Will also research that. I'm not particular about how I get this to work.
Thanks!
Why do Andorid phones get stuck in a year or two?
Welcome to Android Forums, Branda Lus! :)
I used five Android phones in the past years and all of them became very sluggish.
Can you expand on that a little? For example, which phones you had, which Android versions you were using, how you typically use your phone--like taking a lot of photos, or downloading large images, and so on. That might help us sort things out.
Personally, in my decade of using Android, I've never seen what you're describing. Like Hadron, I typically use my devices for 3+ years--right now, in addition to my daily-driver, a Moto Z² Force Edition, I also use my 5-year-old Moto X 2nd Generation and my 7-year-old Kindle Fire HD 8.9" [which I turned into a true Android tablet by rooting it]. Neither has ever been, or needed to be, factory reset due to sluggishness. So your experience is not at all like mine!
By the way, even if you were an iPhone user, you'd still be welcome here. :D
Trustworthy website that pays the most for old phones in New York?
I would go with Swappa if getting some money back is a priority:
https://www.androidpolice.com/2020/01/01/how-to-get-the-most-money-for-your-old-phone/
But if you want to donate your phone, take a look into the iFixit site's donation program:
https://www.ifixit.com/Info/Device_Donations
Keep in mind that for really popular models there's no need for more but if you have a lessor known model or one that they don't have access to but there's a demand, donating can help expand their database of service guides. If they do want your phone, it's a no cost matter for you as they even send you a postage paid mailer.
Hey y'all, I need some help regarding an old tablet.
The tablet itself is just too dated to be all that useful any more.
No matter how much you want otherwise, the hardware is very dated and can't be upgraded and any software that can run on it will also be very dated. That creates a situation were any interactions with online services (web browsing, email/contacts/calendar, online storage services, etc.) will be very limited in functionality and very, very questionable as far as security and privacy concerns. Use to play games or whatever at home, but leave WiFi disabled. Don't connect to any online source.
Okay, thanks for the tip. I actually completely forgot about this post and already moved on. Thanks for the support!
Is there a flashlight gesture?
I've used moto phones in the past that have chop to turn on the flashlight which i find really convenient. You just chop your hand twice and the flashlight comes on, even if the screen was locked. I used it all the time.
Does samsung have something similar? I can't find anything like that in my menu. What do you all use?
Thx!
Those apps Steven linked are probably best option. Best built in function is probably pinning flashlight to quick launch side menu, which should be turned on my default.
I'm lost - please help.
Some further info as follows...
I looked at the "my files" route, but found this convoluted and a little confusing (dont forget I'm a novice) but thanks for the suggestion.
From a google search came the following 'fix' - that gelled with the functions on my wife's S5.
Find and tap settings> Apps
Tap the app that you want to move to the SD card
On the next screen shot - this contains the word storage - tap on this
If the app supports changing where it is stored - a change button appears - hit this button
Tap SD card > then move
Transfer will then take place.
So in fact the ability to transfer is still within the Samsung set up - just a different route to get there!
In regard to es file explorer - my wife has found a third party app that apparently suits her needs. I will however look to Aptoide (My thanks to Xavier Black for this suggestion)
My thanks to all who took the time and trouble to help me with this one
Purgatory
Pixel 4a leaks! A great looking phone!
I've used LCDs and AMOLEDs, and don't get this "AMOLED good, LCD bad" stuff. I've seen good and bad examples of both, both have their pros and cons. For me that's not an issue - I'll judge on the individual screen (my current phone is OLED by the way, but that wasn't a factor in the choice).
Storage is my main concern, because Google have a long history of aiming low in this respect. But maybe if the rumoured 5g version is real they'll put more storage in that? At least the "starting from" in the price leak is promising, as that implies more than one model.
Have to agree here. Even offering 64gb on the regular 4 is a travesty. NO WAY that should be an option on a "flagship". On for the budget line, better have an option with more storage.
Apps onRequestPermissionResulti in fragment
After beating up my head on the wall, I found the answer:
Inside the Fragment, I insert this code to Intent to call the camera:
Java:
Intent intent = new Intent(MediaStore.Action_IMAGE_CAPTURE);
// The number 1, below, is my code for camera
getActivity().startActivityForResult(intent, 1);
And into MainActivity (which fragment belongs), I insert the code below:
Java:
public void onActivityResult(int requestCode, int requestResult, @Nullable Intent data){
    super.onActivityResult(requestCode, requestResult, data);
    int result = requestCode;
I'll feel me so glad if this code could help someone else, because, in the Internet, help is so hard.
Filter
