The LG G7 is a flagship phone
- Smartphones
- 21 Replies
Over a year and a half in and I'm still loving this phone. It just feels right in my hand.
It would be a little surprising for a site or a project not to define what is meant by "open source" somewhere, since there are many different "open source" licenses with different conditions. Some allow you to do anything, including using the code in proprietary (closed source) apps, some require that any project using them is open source under an equivalent license, some forbid commercial use. The term "open source" by itself is not specific enough to tell you what usage is allowed.Well I am familiar with GPL, many Linux distros and open source software use it. Usually you can use the source code, make changes, and make money if you want to, the free is of freedom. I wasn't sure what the term meant because I haven't seen in a wile, I just was trying to make sure.
The site says that is open source, it does not mention any licence. I am a beginner in Android but I already have 5 apps on Play Store.
For eclipse yes it has them pre installed you dont have to install them yourselfand for the GRE PRO v1.32 it has own gapps ?
The approach of this question is possible achieve and this answer above not is a solution.
it would be interesting indeed.....LOLI noticed that earlier and since the quote is not coming for me, I figured it would result in an interesting response.
Is your bootloader unlocked? I assume it was when you flashed magisk, just wanted to be sure you'd not relocked it afterwards.
Is your fastboot program up-to-date? You can get those errors with an older fastboot program (though the fact that you flashed previously suggests it should work).
Did you download the correct firmware? I linked to the 3a firmware because that's the forum we're in, but if you have a 3a XL you should download the firmware for that instead (people sometimes are inexact about the model number so I have to cover all of the possibilities here).
To be honest with you, I think drag and drop app creation utilities like this can be quite hard to learn to use, and ultimately don't give you the power and flexibility you need. This only comes from using a proper development environment, and learning a programming language - either Java or Kotlin.
I've had a quick look at Sketchware, and it's taking a zero code/drag 'n drop approach, which in my experience is only suitable for really basic apps. I really think your time would be better spent learning how to use Android Studio, and how to code.
love your cute babyHere is a screenshot of what happens sometimes when I try to take a photo. You are undoubtedly right that I am doing something inadvertently but I'll be darned if I know what it is. This can be very annoying especially when trying to take a photo of a child or a dog or something else that doesn't hold still.
usa today protonmail
i really love it too thank you so much for the answer
