Help imei problem, Restoring or changing imei?
As an aside, you say it might have changed when you had it repaired at some time. Do you know what the repair was? If they replaced the motherboard then the IMEI would have changed then. That's the only reason I can think it could happen legitimately.
It's possible that your problem may have arisen because someone else changed their IMEI. Some people do that when they've got theirs blocked (e.g. by stopping paying a contract, or because they bought a stolen phone), and if you were unlucky and someone cloned your IMEI then it would be blocked once this was detected. That's only a hypothesis, and it may be something simpler (including a typo when someone was trying to block a different number - nothing is impossible). But your service provider is the best outfit to talk to about a phone block anyway.
Instagram API
Hello friends,
In Instagram, I want to show a list of those who have followed before and left the follow-up. I think I need the user's followers first. *one
And I want to be able to show a list of other users that are blocking the user. There are mobile apps that do this. *2nd
I've been researching what data Instagram gave us to solve these two problems. However, I could not reach a clear solution.
I will do the project in Android Studio, I know how to send a request with retrofit. For these two issues, exactly what URL do I need to send a request to, what can I do, ... can you give me some ideas, advice and suggestions on my research?
Below are some Instagram URLs which can help me? I guess I'm not very good at determining that, can you please help me?
https://github.com/postaddictme/instagram-php-scraper/blob/master/src/InstagramScraper/Endpoints.php
My Girlfriend Nags me too much about my case!
nice looks good, might have a go at it as well. let us know how you like this one.
Will do
Well it just came in, so far it's very well packaged and here is my thoughts in it
It has a great feel to it when you hold it in your hand with the Note 10+ the ports are not blocked and are easily accessible, the buttons for volume and Bixby feels very nice when you press it down.
The sides and all around the Note 10+ doesnt feel all bulky in my hand that I had to deal with my old case, and it's perfect size, the only complaint I have is where the ports are feels kinda bumpy
The Galaxy s7
Everything is good but only one thing it suffers
Is when it was updated to Android Oreo, Oreo has a issue with draining battery a little bit faster and watching 4K videos on YouTube does lag a bit
It has expandable storage up to 64GB, 3.5mm headphone jack, 4GB of DDR3 RAM, wireless charging
Get value and compare it to file content same value
Hi ! I want to create a small program with android studio that can take a value entered by a user and compare that value to another identical value that exists in a file stored in the internal memory of the phone. If this value exists in the file, select the file in question and send it to a server... Could someone help me with that ?
I'll post some code I use in my own apps to get you started. The rest you can figure out on your own with a little googling and asking around.
The BufferedReader is perfect for this situation. You can use it to get the contents of a file on your phone and compare the contents to a string which is what it seems you're trying to do.
Method to read file contents - getFileContent():
Java:
private static String getFileContent(String file) {
  String content = "";
  try (BufferedReader br = new BufferedReader(new FileReader(file))) {
    StringBuilder sb = new StringBuilder();
    String line = br.readLine();
    while (line != null) {
      sb.append(line);
      if (line != null) {
        sb.append(System.lineSeparator());
    content = sb.toString();
  } catch (IOException e) {
    e.printStackTrace();
  return content;
Using the method getFileContent():
Java:
if (getFileContent("/path/to/filename").contains("string-to-check")) {
  // run your code here for a match
} else {
  // run code here for no match
Good luck ;)
Double end cord
FYI the JBL Flip 4 speaker uses micro-USB for power and charging. Power-banks usually have standard sized USB power outputs, it may have micro-USB and/or type-C USB as well, all depending on the particular one you've got there. For a speaker from a power-bank, you can just use any phone USB cord, provided it has the appropriate connectors.
Filter
