Help iTunes Equivalent for Android Devices?
Needs to be noted that Apple recently announced it will be killing off iTunes as it's own multi-function service and just let all its features just move into their own discrete ones.
https://www.digitaltrends.com/computing/apple-kill-itunes-wwdc-2019/
https://www.npr.org/2019/06/03/729290123/itunes-death-is-all-about-how-we-listen-to-music-today
As for Google Music, it sounds like your audio library was still in the stages of being uploaded. Confirm that's all done and then see if the app is still taxing your phone's resources so much.
Adapter for Samsung Galaxy Note 10+
You might consider an inductive charging plate. (wireless charging) You can then charge your new phone and use the oem usb connection for your earphones. Another work-a-round would be to stream your audio BT as you are charging via the usb port. Easy solutions. I don't know of a charging cable that has the headphone adapter that will work simultaneously though it may exist.
We are discussing the Note 10 and 10+ here if you'd like to join us. https://androidforums.com/devices/samsung-galaxy-note-10.16515/
Do you know about this app?
I found a guy recently who is using an app which is like a personal blog, he posts some content and everyone who has installed this app can view the content.
There are options like 'Who am i', 'Messages' included within the app.
The name of the app is Private Blog, with a yellow money bag icon. The icon changes in the notification bar to a blue thunder symbol. This isn't available on the play store either. Tried Google, haven't found a single clue.
How did i find this in the first place? It was through a sponsored Instagram, swiping up on the story downloaded the app and i installed it to see what it was.
What i wanna know is if this app is custom made or available for public use. Like it has a dashboard where you post stuff from and receive messages too.
Or it is a simple blog which was made into an app using web view
Link to the screenshots:
http://bit.ly/2TFHD50
http://bit.ly/2P5aRLO
root access.
Thanks...... It seems like no matter what I do, I just can't get /system mounted as R/W.
Every tool I've tried (even those with an r/w "switch") fail to mount it. EFS File explorer, EG.
I'm going to create a flashable zip and try an install from TWRP next.
I'm running (patched by Magisk) version of stock (build 10F) android Nougat for the LG V20 (US996).
Is it worth rooting?
I'd recommend you don't need to bother going through the rooting process unless there are specific reasons why do want to. But a lot of that depends on just what model is it and which version of Android it's running. Once you root it, all management becomes your responsibility. Things like OTA updates will be a serious judgment call on your part as applying them to a rooted device might work out fine or it might soft-brick your device so you have to go through a lot of corrective measures. A rooted device is also more vulnerable to being compromised as it only has half-measures to the integral security policies that are a part of a non-rooted device:
https://www.bleepingcomputer.com/news/security/android-security-a-peek-behind-the-scenes/
You do need to be more vigilant about everything you do that involves any online interaction. This pertains more to a smartphone as they're more multi-functional in day-to-day usage than a TV set top unit but it's still relevant.
If however you just want to learn more about your device at a deeper level, than rooting it is less of an option but more of a necessity.
Startup error
Hello. I decided to write a small android application. Created an HTML file, and two folders with resources to it. It works well. I tried to create an apk file based on it using android studio. And when I run this apk on my phone, I see "Error: no valid storage adapters found". What could I do wrong? I know that there is little information, if something is needed - say, I will add. Help me please.
Apps like Netflix, Amazon Prime, Twitter, Facebook Instagram LinkedIn not working over Wi-Fi
Is this problem happening only when you're connecting to one particular WiFi network or is does this happen when you're connecting to any WiFi network?
If the former, it's probably something to do with just that one network. Try rebooting both your phone and the router and see if that fixes the problem. Otherwise, please provide more details on the router model and the general set up on that network. Is it your home network or a work one?
If the latter, that indicates it could be a problem with your phone. Is your Mi A1 running Nougat or Pie?
Phone case
Afternoon all,
I am having to use my old elephone p8 mini until my upgrade. Does anyone know where I can get a decent case from? Want one of those magnetic 360 cover ones but can't find one for this model
Failing that anybody know if another make/ model has same shape/ size so can get one of those cases?
Regards James
Tagging as a service; would that be useful to you as a developer?
Hey everyone, I'm a backend developer and I have a few API services that I'm looking to make public.
I'm here to test the market for a specific API that manages tags.
What you can use this for:
- managing tags such as adding a tag, editing a tag, removing a tag
- searching tags
- storing millions of tags
Applications:
- hashtagging is the most common
- tagging things internally for faster searching
- tagging things for storage
Benefits:
- performance, performance, performance
- scaling is all done on my side
- looking to make this free but also paid for really high traffic users
Its a generic and flexible solution. I'm sure there are other creative uses for it.
Looking to answer the following questions:
- what are your thoughts?
- would you use something like this?
- is there another backend service that you often have trouble finding?
Thanks in advance!
Filter
