elf83
Member
place the apk on your sd card then download AppInstaller by FunTrigger from the market then open app installer and scroll down tell you see the gingerbreak apk and install it.
I just installed the Primitive Sideloader ( used For Atrix )to my pc to intall it from the computer directly to the phone
http://www.atrix4gforum.com/motorola-atrix-4g-apps/primitive-sideloader-a-program-for-sideloading-apps-on-atrix-without-root/?action=dlattach;attach=2876 theres the link to it.
By the Way thank you so much i was having problems rooting the hard way.
