Blackhawk1969
flash_image.bin is what you should be looking for.
Downloaded the file. Did not see a flash_image.bin anywhere.
Will try to download to phone and see.
Just a recovery.img, nothing more. The file properties indicate just 1 file, didn't see any file piggybacked either.
The flash_image.bin is usually from 9-10 KB, the recovery's are around 4MB
I found the Recovery.img but couldnt find the flash image.bin i did find a thread "[GUIDE] Rooting, Install Custom Recovery, Install Custom ROM CyanogenMod 7" I used App Flash Image GUI from the Guide post and it seemed to work fine..it had the same recovery file listed, but for some reason my Terminal was not finding the Recovery to flash. Flash Image GUI worked it seems.. wiped Dalvic Cache and Cache, it told me to reboot the phone with a reboot button and it took about 3-4 mins to get past the Android screen, probably wiping Dalvic Cache from what i read is what took longer than normal for it to boot, booted up..home screen and so far it looks like im on track but going slowly..thanks alot for your help too. now i just need to Nandro backup and test it.
