bogeyone12
i have trouble all the time with gingerbreak 1.30 it takes so long and never reboots or roots my phone wats going on ... what am i doing wroung ..??
Hey guys, I got it rooted, and in superuser mode but when i type the flash_image recovery /sdcard/recovery-RA-optm-2.2.1-GNM.img I get an error that says flash_image: not found
I have it in two spot on my sdcard just in case, one being in a folder with the gingerbreak apk and one not in any folder... what am i doing wrong?
This never works; it just continuously loads, saying: "exploiting.." I tried all three versions, neither of which work.
-I have debugging on.
Make sure your device is 2.2.1. if that is the version you are running then gingerbreak should work. The app also needs to be on the phone, not the sdcard.
Oops, hit submit before I was done. Any way, I tried gingerbreak out, and it worked fit both my phones (mine and my wife's phone). I left the apk on the sd card of both phones when I did it.
Ok guys, I downloaded the gingerbreak apk to my SD card 1.20 and 1.10 and I have tried to several times with Astro manager, Es file explorer and even the office app from metro but every time I try to install the apk it gives me the Following error:
Parse Error :There is a problem parsing the package.
I have download the apk several times as well and still the same issue. I even formated my SD card and tried without success.
I have and LG Optimus M with android 2.2.1 from MetroPCS.
Any solutions,
EDIT: I found the problem: It was my antivirus that was looking the file as a trojan virus. Disable antivirus while you download the file.
Thanks
im trying to root 2.2.2 and it stays at running exploits, etc. I remember last time i rooted an optimus m it was a bitch too . im about to try z4 but im not sure if it works for 2.2.2 . any suggestions?
IVe been reading the posts but I havent seen anyone so far that has had a problem just rooting the phone, can using Gingerbreak itself cause problems without the User trying to change to a different rom Kernel etc? just clicking Root to get rid or change to something different than the Metro PCS HELLO HELLO HELLO... on startup? 2.2.1 stock
not worth a signifigant risk for something so minor on my perfectly working phone. it even uses the flash player 10.2 fix that someone posted without a custom ROM
Your going to need to go to the market an update the Superuser app and the binary. Then you need to get a Busybox installer from the market and install Busybox either to /system/xbin or to /system/bin as the exploit does not install it for you.
You need to install a custom recovery and make a backup of your system from the recovery menu (nandroid backup) so when you delete something important you can restore your system and be all good again.
The exploit does not install the proper flash_image to your /system/bin, so you need to do that with a terminal emulator or ADB shell commands. You will also need to change the permissions on the flash_image once it is installed.
The proper flash_image is necessary to flash the recovery.
