Swainsmith82
Android Expert
I found the culprit that causes 1080p to be purple.. Dun dun dun..... F KERNEL!! No matter which form of the f kernel causes this on 1080p. So if you want 1080p you'll need to flash PG's build from firmware C without a loki'd kernel or over clocked (in my opinion we don't really need oc anyway) which is also lokid. Here's the thing though Playful God made a cwm that is loki'd, but because the aboot img is what's causing the factory reset (according to bliss) it's not perfected yet, but it does install, boot, and work. Unfortunately we are not allowed to host links for Bob's rom so I can't give you a modified build that does not flash the F kernel. If you wish to use his build you will need to do this on your own, or you can simply flash PG's build. If anyone has the ability to make a working loki'd C kernel, that would solve everything, but keep in mind that PG did this already and it did not boot. So next best option is flashing his loki modded cwm recovery. You can still get into 2nd-init after bricking without factory reset by tapping the volume down button at initial boot.
There is a plus I've found to being on firmware c and PG's build .. My data speeds increased by 4mbps from what they were on F and just using the c modem(which in my opinion didn't change much)..
So here's the cwm modded recovery thanks to non other than
PLAYFUL GOD. Dev-Host - l0-CWM-test.zip - The Ultimate Free File Hosting / File Sharing Service I urge you all to show him some major respect and appreciation for all he's done for us. Even if you're not using his build he has helped everyone of us in some way. He has continued working on the Motion when it seems everyone else has moved on and I know those that use Bob's build have gotten a lot of stuff from PG's build to make it work better so please tell him thanks..
