that is terrible. I got 40 hours on and 5awake yesterday
5 hours awake and 40 hours on? were you on 4g the whole time? Were you browsing the web? Do you have the display at 10%.
But people always modify their their habits to extend something. They own a house and they do everything to make it more efficient with better windows, insulation, Energy saving appliances and so on. They cut the heat back to save money, Open the windows instead of running the AC.Hmm some people are just here to believe that these batteries are a scam. I live in a 4g area. I went to work 100% charge. I only have htc for sense on and gmail sync on. I I used my phone less then an hour. with in 8 hours I was less then 50% that is with stock battery, with mild usage my battery would have most likely been dead already. I will take any improvement I get over stock battery. A person should not have to shut off half their features or to root the phone and flash a custom rom to get decent battery life. I can root my phone but I am not going to just do it to improve battery life, I will do it when CM 7 is available for this phone.
I welcome any improvements in battery life that this battery brings. Awake time doesn't mean your phone is not doing anything in the background.
I can and I do get a drain but its not massive. My Dinc would have more of a drain overnight than my Bolt.Okay, maybe I was taking it a bit personal. But I'm just trying to help those that are debating on buying these batteries.
I just do not get why you think this is so terrible. You guys are ignoring the uptime like it does not matter and it does. Some people are reporting 8 hours of battery life without any on time.
Are you telling me that you can leave your phone on all night while you sleep and you don't get battery drain?
I just don't get your point of view.
Thanks Cavemansol, I've been keeping up with that one and definitely got a few good laughs from it. Good stuff.
I get half a percent an hour drain on idle. my point is that your express battery seems to be getting worse life than my stock batteryOkay, maybe I was taking it a bit personal. But I'm just trying to help those that are debating on buying these batteries.
I have 4g turned off as I do not have it in my area yet. display is on 30 percent. probably half of that day was internet, and the other half was talking/texting5 hours awake and 40 hours on? were you on 4g the whole time? Were you browsing the web? Do you have the display at 10%.
Nor*Cal said:Battery at 55%.
Up Time = 21:27
Awake Time = 1:08
Battery at 41%
Up Time = 34:36
Awake Time = 1:53
It has been well established that the 4G radio is a huge battery drain when in use. If you're not even using 4G, it shouldn't be come as a surprise that you're getting better stock battery life than he is. Then why are you comparing your 3G-only experience with someone else's 4G experience?It has been well established that the 4G radio is a huge battery drain when in use. If you're not even using 4G, it shouldn't be come as a surprise that you're getting better stock battery life than he is.
There's really no point in comparing your experience to someone else's if you're not even using the same base cell technology for most of your phone usage. On top of that, there are many subjective aspects to battery life which make it hard to compare individual cases even if you WERE both on 4G. Signal quality and strength also can make a large difference. Unless you want to go live in the OP's house with him and compare your experiences then, you're simply giving a VERY subjective commentary on your own experience.
All he is doing is giving a semi-qualitative evaluation of his experience with the aftermarket battery and if you don't believe that, then don't buy the battery and don't comment on an experiment that you clearly aren't involved with or have firsthand knowledge of.
. whether or not he had 4g turned off has not been stated, I do not think. I do admit that I did not consider the drain difference in 3g and 4g earlier thoughI can and I do get a drain but its not massive. My Dinc would have more of a drain overnight than my Bolt.
If someone want to sell me one of these batteries let me know . I have no need for 2 and I already have an external wall charger
I got my batteries today. Did anyone else get one black and one white? one of my battery is black and one is red, lol. I didn't know it was going to be that way.
So did people order off the site or from the amazon seller? Or are they the same...Thanks!
if everything is as subjective as you are trying to make it seem, then there is absolutely no point in anyone sharing their experiences with these batteries. if that is true why did you bother coming in this thread?
norcal stated that he spent that entire time in 3g. whether or not he had 4g turned off has not been stated, I do not think. I do admit that I did not consider the drain difference in 3g and 4g earlier though
please show me where I said I didn't believe that he was giving a semi-qualitative evaluation of his experience with the aftermarket battery, because I do not believe I did. I was simply offering my semi-qualitative evaluation of my experience with the stock battery
if my posts are just cluttering up this thread, then yours are also, so why do you continue to post?And why were you posting your semi-qualitative evaluation of your experience with the stock battery when this isn't a stock battery thread? If I'm not mistaken, this is a discussion about the 1700 mAh battery, something you have made clear you don't own and probably have no intention of owning. There are hundreds of other threads about the stock battery life on this and other forums.
My point is this: members who actually own the battery this thread is devoted to are commenting on their own experiences. You don't know what their individual experiences are with the stock battery and now the extended battery, and you have made it clear you are doing just fine with the stock battery. Why do you (and several others in here) insist on cluttering up this thread with inane and unproductive responses that do nothing but frustrate the people that are actually contributing useful information?
Since you've only been a member of these forums for a few weeks and already have a significant post count, I certainly hope that you haven't racked up your hundreds of posts commenting in a similarly disruptive and "me-too!" manner without actually contributing anything interesting or new or informative.
will tryout for a few days see how it goes ill give a review and thoughts
and if its worth it
