Root 2.0.1 sbf
ludachris
hey i was wondering if anyone could email me the 2.0.1 sbf file because my computer wont download it. i need to downgrade my phone from root to send it back to verizon and the sbf, for some unkown reason, will not download to my computer from meadiafire. if someone could help i would greatly appreciate it. thanks
i cant my phone is in a loop of the boot screen and wont turn all the way of the on. i really need this file so i can restore my device to factory so i dont get charged full price for a refurb droid. any assistance would be greatly appreciated.
the 2.0.1 sbf files are 130mb which is much larger than most email accounts can receive. I dont think you will have much luck with this. Be better off finding another computer to download it on or figure out why your computer isnt working correctly
I am having the same problem. Not sure what to do next. When I download the above file where do I apply it? Any help would be aq huge help
Depending on which recovery you are using move the file to the root of the Sd card.
Make sure the file name is update.zip
When in recovery mode choose install from SD card, make sure to wipe data / cache first.
that should be it
that should be it
When did it get so easy? Lol...no more adb and rsdlite?
When i originally flashed OTA 2.1 version i never had to do rsd lite. Just the Update.zip piece. Now when i flashed sprecovery SBF i used the RSD lite.
