This update appears to have been pulled (probably temporarily) as an OTA update.
edit: The update is now available again OTA. This guide will still work if you prefer to install manually, or don't get the OTA offer.
This update is for stock froyo release 2.09.405.8 only.
You can apply it manually by following these steps:
If you have debranded your phone you MUST have your goldcard in the phone.
Read that last bit again.
- Backup anything you need, in case of problems
- Download this file and put it on your sdcard
- Rename the file to 'update.zip' (ensure it is not update.zip.zip)
- Power down the phone
- Start the phone in recovery (press vol down and power together, then select recovery)
- After recovery loads press vol up and power together
- Select to apply update.zip
