Root 342 probs?
F
faber78
Guest
well been running 342 for a bit and seemed pretty good.
but just today for the first time i had a couple probs.
- gps kept force closing (first time i used it was today)
- phone turned itself off and random reboot why just sitting charging.
im not really worried about figuring out why, as i have uninstalled and messed with all kinds of stuff....just wondered if anyone else had issues and with what....
Been on it for 2 full days and had one reboot when I was connecting to the computer and moving between USB and charging (no apps running on SD card). Have just used the cellular GPS location for a couple apps and no issues, but not the real GPS yet.
So far happy with it.
Nope, you're the only one. :D
^story of my life
^hd the reboots on occasion hooking up comp.; use to that with anything im running.
apps used gps o.k. before for me also.
it was today tried gps....ive down a lot of messing with it though.
apr. the replys guys....:)
^story of my life
Mine reboots when I try to run Droid overclocker, but QuickClock works fine.
oh yeah....forgot that one, had that too....other oc app works for me 2.
rummys reboots also....
forgot;
its funny the gps is fine just setting here on looking at maps or with navigation on; but when i was driving itd go for awhile then reboot.
i turned down my oc to see if that help with that odd reboot deal....
forgot;
Mine reboots when I try to change settings, overclocked or not.
When i ran the 342 leak I couldn't access settings or set wallpapers when I flashed a theme that was ported specifically for 342. So I gave up on it and went to Liberty.
Neither have I.
oh you meant in rummys oc....my bad.
kinda interesting winimage will open up the system .img or whatever it is in the 342 .zip to get to original framework and other stuff....though since it already on phone can just copy stuff from system to sd card already anyway....
Yeah jrummy.
I also notice I get a 1X signal often; before I would get 1X very rarely for very short periods of time......now it's very often for long periods of time.
This alone is making want to go back to 2.3.340.
Yeah jrummy.
Yeah that would be really annoying. Haven't had that more then usual.
I had the 1x problem too... i ran it all of an hour before i got fed up with it and flashed back to 320 using maderstcok.
3 weeks running with zero issues
I have been running it for a week and I haven't had any problems either.
It's been running so good for me I haven't even considered over clocking.
Although, I haven't made many tweaks other than the BWC theme that bouchigo put up. I am getting tired of the stock launcher, so I will probably put go launcher on it and see what happens. I used the crap out of my phone yesterday without issue. Played a few games, read a ton of rss feeds and used maps, plus the usual calls and texts.
Battery life it still great. No reboots. Still diggin this build.
The first thing I did was replace the home launcher....been using go launcher ex :D
3.4.2 is unusually stable for me. Not running it anymore though (I'm back to focused) but it's gonna be gdlk when roms get updated to this build.
GoLauncher on 3.4.2 is so smooth. I've been running it with imoseyons tweaks and honeybread theme since the end of February and I love it. Battery life is just phenominal
i went back to fis for a bit. ill prob. go back to this eventually.
hoping to see some development on it.
not really sure why i went back; think its kinda a toss up for me; ill prob bounce back and forth until something comes out.
i was having a hard time getting my dialer like i want it in one of the themes i use; but not really anything worth sweating.
I thought 3.4.2 was smoother and more responsive than Fission, but after using 3.4.2 for a week and now back on Fission, Fission is smoother and more responsive......and best of all, no 1X signal :D
Maybe if ROMs are made based off of 3.4.2 it will be better.
yeah, i think they all tend to slow down a bit after some time....
but im guessing the same; a well developed 342 rom should be pretty sweet.
