Gman9831
I'm no Senior
So if you guys take out your sim card do you not have any signal or does it look like this http://db.tt/KWVFsN69
Oh I forgot about this I had went into the lg service menu & set the ICC needs activation to off so now if you take out the sim card you just get no 4G but everything else works
what would happen if you put the sim in another metro 4g phone???
Not sure never tried it but they say the cat3 (current) sims are supposed to be interchangeable
Service menu a no go on 10 #*#*4636*#*# works though.... wasn't there a thread on this?
Yes there was a thread a couple of months ago where me & Sepero were tryin to get to the stock android hidden menu(*#*#4636#*#*) On stock rom but LG had blocked it even though we had found an app that could get in it but it pops up saying incompatible with this device. LG's done a real good job blocking it.
What did you use to get to the menu? I forgot the other code but ##lgservicemenu is a no go.
Sent from my MS770 using Tapatalk 2
Press dial (the green button) after entering that code.
Keep in mind... I'm on jb kang rom
Sent from my mind using an LG ms770
I have ICC off, and it only allows emergency calls.Oh I forgot about this I had went into the lg service menu & set the ICC needs activation to off so now if you take out the sim card you just get no 4G but everything else works
Though, when I turn off n-work lock, then I can make any calls and access the internet. 4G is also disabled on mine. Mine doesn't show 3G, but I don't think it ever shows 3G for lack of it in my area. It shows evdo or 1x.
Did you have to input any special Sim unlock code for another carrier Sim card?Sammyz I had put my S3's sim card with unlimited data into a motion that had a sim with throttled data and it still worked
There is no such thing as a Sim unlock for the Motion. This is a CDMA phone and SIM unlocks are for GSM phones, or certain world phones that Verizon and Sprint have. The Motion is stuck on Metro's network and will soon be obsolete since the Metro CDMA network is going away. The "SIM" card in the Motion isn't really a SIM card like on T-Mobile or AT&T phones.Hi fellas, I'm new too the forum. I have been trying too get answers from MetroPCS about my lg motion 4g phn. I ask them to provide me with the Sim unlock code with no luck. I want switch to another. How can i get my Sim unlock code without MetroPCS?
Thanks for the answer. I hoping there was another alternative besides buying a new phn.There is no such thing as a Sim unlock for the Motion. This is a CDMA phone and SIM unlocks are for GSM phones, or certain world phones that Verizon and Sprint have. The Motion is stuck on Metro's network and will soon be obsolete since the Metro CDMA network is going away. The "SIM" card in the Motion isn't really a SIM card like on T-Mobile or AT&T phones.
Yeah, unfortunately since the CDMA network is going away it's not possible. It can still be used as a Wi-Fi device at home or out though.Thanks for the answer. I hoping there was another alternative besides buying a new phn.
Can you expand on that? Id like to know more on that.Yeah, unfortunately since the CDMA network is going away it's not possible. It can still be used as a Wi-Fi device at home or out though.
