Hi, I have a HTC Desire which I have got on contract from O2. I am looking to root my phone and install and run a custom ROM.
So, why am I starting this tread, well basically I
So it can be any SD card but not ideal to have it on the phone card in case the card screws up or the phone screws the card?
I have a MicroSD card in my DS, I could just use that? Is the Goldcard a file, would I be able to transfer the Goldcard to my PC to keep as another copy? Are you basically saving the ROM or RUU as it is now?
I am also worried about losing my phone book, SMS and bookmarks that I have saved using Opera Mini, how do I do that?
Thinking about it, I can save SMS and phone book using a PC program called " My Phone Explorer ".
Won't have time now to make Gold card so will try over weekend and then attempt rooting next week
lucky dog! wish mine still had hboot .93. i am stuck with stock 2.2 with unrootable 1.06.
Lets cover that when we get there though.
I right click on the Goldcard tool programme and select OK (I am the only user on the PC and set up as Admin and don't have a password set up) but I keep getting "the application failed to initialize properly (0xc0000135). Click OK to terminate the application."
What do I do now? Is the programme I have downloaded corrupt? Help!
