lubberlick
Simple question. How do I discover if any version of A2SD is pre-installed by a rom? Would be nice to know so I don't go flashing it when its already there.
Ahh I was hoping for something a little more "type this into the phone, if it works then its loaded if not then no". Something I could do without digging and reading![]()
i wish it was that easy. but one good habit is to checkout what the rom has to offer before flashing it. i always head on over to the devs page on xda or whatever there main site is to check out the goodies before flashing. you should know what you are flashing at all times. do not just flash just because someone says to do it.
i think that most roms these days have a2sd built in. i know the mik rom's have it. and all of the sense 3.0 roms have it as well.
i get confused reading about this and another like named app. I see the option to move apps to sd in settings, apps.
How does this work? does it free up memory and then run well from the sd card?
don't know what the advantages and pitfalls of this are. Is it reversible?
