Didn't see any changes. No biggie I just wanted to give it a try.
Do you already have the rom on your phone?
all the ssystem files are there. it should be a full ROM package...i went to recovery and did wipe data factory reset and then dalvik cache and then system then i flashed the rom and it went to where it says samsung transform ultra and gets stuck there like theres no rom at all. basically you have to have the stock rom installed for the starscrom zip to uupdate youre phone. if you intalled it with the original way you wont see any difference.Correct.
to confirm.. do you have Star Settings?Ok I did what you said and it worked. thanks for pointing that out. I stand corrected.
ok guys, hold back on this till i can work on the zip and see why it's not working for you. Must be something wrong with it. It should have installed an entire rom but i have a feeling it's not. But i will get it working.I know I just manually installed it myself just for reference it didn't install task manager either which is in data/app/ also.
it should wright over my files replacing them with new one.... i will look into it later tonight just incase.
Dont sweat it. I know whats wrong.. The script is missing. Ill fix it once i figure out how to write it
in order to make a CWM.zip there is a folder named META.INF. inside there are scripts that tell CWM how/where to write files and such.Isn't it missing the build.prop
Edit: nevermind I figured it out just don't know how to fix it. Its a little over my head.
Flashed the rom but star settings seemed to disappear.. could I get the apk or the installer that was used please?
