MarmiteX1
Hi there,
I am trying to backup my device using adb. So i got a set of files that i need to root the device.
The problem i am having is that i keep getting the following message:
adb: unable to connect for backup.
so i then checked whether my device is actually connected which it is so i then ran the command adb devices and i get a device listed but with the value of offline
I then ran a command to check the version of the adb and the version is 1.0.29.
By the way, i do have usb debugging enabled and PTP enabled because i read PTP works so thats why i have it enabled with PTP.
Could anyone advise what i should do?
Thanks in advance,
Thanks in advance,
