Root Adding OC to 2.2.2 Kernel help please
sammyz
LG Whiz Kid
Can a dev please tell me exactly what they did to add OC to 2.2.1 kernel so I can figure out how to add OC to 2.2.2 kernel? Thank you.
I have source of 2.2.2 Kernel and reppards r.O.C.K. v0.3 Kernel
I'm pretty sure you can find this on github and compare the files.
this thread will give you an idea of what you are seeking.
yea this thread is helping, some of the lines cause it to error though, I just remove it, some of the files also cause it to error and I put reppard's source file(s) on where the error(s) are located...also idk how to get to the optimus m kernel section of github...
