Ok, first some background information.
For the last 2 years my wife and I have been with Verizon and used Motorola Razr android cell phones. Never had any issues with data usage because the apps. were closed when we finished using them on those phones.
Recently we switched to Consumer Cellular and bought Samsung Rubys which are also androids. I really like the service and the phones. There is just one problem. We were using way, way too much data. We used 35mgs. in just two days. I left the phone in the car in an area unconnected to wifi and used 23mgs. in just 5 hours, not realizing that I needed to manually shut down apps. because the phone doesn't it like my Razrs did. This was totally unacceptable!!
Enter Advanced Task Killer which was recommended to me by a tech for Consumer Cellular. The problem is that although it does shut down the running apps. the phone seems to be using more battery and also is definitely running slower since I installed ATK.
Now I'm reading that androids manage the apps. well enough by themselves and don't need any extra apps. to 'help' them out. My question is what am I missing here? How do I configure this phone to shut down the running apps. when I am finished with them? There is a manual app. closer that is relatively easy to access and use but I don't think I should have to do it that way.
Any feedback would be very much appreciated.
Regards,
Len
Regards,
Len
