You have to open it first for it to start runninh though. It's going to appear in your notification bar.
Yes, I did open it and it's running well now.
Google Play Store does not use any unnecessary data unless you have apps set to auto update. Just turn it off. And if you don't have it, where do you plan on getting apps? I strongly discourage anyone from going to apk download sites as that is a very good way of getting malware apps onto your phone.
I mis-spoke on this app. I meant Google Play Services, not Google Play Store. I think I do need to re-install it because it is used to update apps. from Google Play. So I will re-install it.
