Help Ally Factory Reset
AllyNati
Ok Peeps,
Phone has been acting kinda spotty lately.
I think a factory reset is in need, but I want to clear all of my bases.
1. What's the best way of physically resetting the phone?
2. Should I remove my SD card before the reset?
3. Contacts are backed up on Google & Lookout. Apps on Astro & aTrackDog... Am I missing anything?
Thank you in advance,
AllyNati
Ya, un mount the sd card. The method i used was i flashed clockwork recovery in rom manager, booted into recovery, and then found factory reset, and voila, boot up after
All is done. Thank you.
I spent an entire day getting things back to the way I had it.
Pain in the butt!
But I will admit, my internal memory skyrocketed from about 20m free to over 80m!
That alone made it worth it.
I now have more apps that I had wanted and I'm still at over 30m free.
Anyone have low memory problems, I highly suggest it.
Just be warned, even with everything backed up...
it takes for ever to reprogram everything again.
