alpha GB 2.3 aosp
If that were the case why is it in it's own folder called recoveries
Wasn't to me, I thought rom manager would have grabbed it from anywhere on the SD card once it couldn't find the old one.
Cause it looks prettier there!
Hell I just woke up, and still had cobwebs when I tried it, wasn't thinking about the process just read the steps.
NP we are busting your chops, wake up, LOL
recovery-clockwork-3.0.0.5-heroc.img ok on aosp v9.9.2 (non GB)? seems obvious it would be but doesn't hurt to ask!
Here is a random question. Does the that cool CRT screen shut off animation work with this ROM yet? ;)
I know, I know, it is pretty trivial, but I always thought it was neat looking. Haha. :D
Yes - You need to adjust your DPI in build prop from 160 to 159....
Then turn them on in CM settings.
Yeah, I actually found that in the AOSP Gingerbread WIKI. What a coincidence. :D
So, would adjusting that only affect the AOSP Android 2.3 ROM or would that affect all of my ROMs? I do want me some CRT action. :)
about to install the new TE, then the new recovery onto AOSP 0.9.9.2. In doing so, I found the directions on xda slightly inaccurate. The name of it in my app folder is com.androidterm.apk, not com.android.term.apk.
sucks when u realize that, because it takes a while for me to peck the mount command. was going to do it from adb on puter, but built new rig, so not installed, then needed jdk; started to get monotonous so just went to TE.
I have found a far more effective gui way of uninstalling system apps: titaniumbackup. is there any reason not to do it via titanium, the simpler way? only other gui app i've found to do it was es file explorer, but it was fickle and prone to buggy reaction when removing system apps (once upon a time).
Is there a reason why you are posting this in this thread, has nothing to do with it ??
image not found when attempting to install v3.0.0.5 recovery. that's w/ new TE. (1.0.0.21?); going to try method II.
eidt: method II worked fine; TE is just a PITA.
is there a reason why u r so grumpy/ill tempered as of late? :D you were just talking to rob about how to flash the new recovery. seems appropriate, despite not being strictly related to GB aosp.
The 1/7/11 gapps are specific for the GB rom. In clockworkmod recovery, go to the partitions menu, format boot, system, data and cache, then wipe dalvik cache. Flash GB rom, then the gapps, then reboot
why is that andygu3? i tired that 1/7.11 on aosp 9.9.2 and it wouldn't allow market, gmail, etc. to load. rebooted to 3.0.0.5 recovery thinking i would just go back to 12.12.10 gapps (day before the new market I think) and now in endless boot loom, nandroids are not working; all started w/ that stupid gapps.
there is now a 1.15.2011 up on cyanogen wiki; would that not also work on the Hero, or at least supposed to? i'm just confused now because i thought the mdpis were universal and should work on 2.2 or 2.3 aosp. :confused::eek:
simply, can anyone please point me to a post 20101213 gapps for aosp hero v.9.9.2? 12.13 has old look and 20100107 or anything newer is incompatible.
No I believe they are propitiatory to each, I posted the Dec 13 Gapps for you again, let us know how you make out
ok....Only flaw I have found in newest release (except for same old things...camera) is the No Frills CM CPU - Caused freezing and reboots....i DELETED AND HAVE GONE BACK TO SET cpU - ALSO - hotru 'S new kernal....included in the ROM Can handle 19mhz like decas can from Ver.2
I still use OC widget, works fine for me
JIT is now disabled and VM Heap is lowered to 16m
Thanks Don. Long story short, Gapps (from 12.12 or 12.13) would not update the market and I never really tried to fix it until recently. I tried to both manually upgrade (via apk) and via flash, but this was after downgrading to amon_ra as cwm 3.0.0.5 backups both failed me (not renamed or anything) after installing that GB gapps and attempting to recover due to inoperable market/gmail et. al.
amon's recovery for Hero doesn't allow one to toggle signature verification, so it would abort. restoring the recovery I now loathe and will never use again (CWM 3.0.0.5) would not fix the problem either as it was complaining about some sort of deprecated scripting used for the newest vending.apk onlne for flash (2.2.11), so downgraded to green text CWM and flashed that way (after toggling sig verification of course) and all is well now.
I would not trust any backup left to CWM 3.0.0.5 if I were any of you, hahah! 1st and last time I ever relied on 3.0.0.5, and wondering if I'm foolish to think the previous version will be there when I need it most.
v2.5.0.1 has not failed me, hence why I have not tried v3.0.0.5 yet. And yes, no troubles with flashing GB and I now have the latest market, thanks to the google servers
The no frills app works great here, strange mahalo:confused: Went ahead and deleted oc widget for now
