tripdoc79
A few things:
1) I would not use the source code from the LS660
1a) It's hardware is different than the MS690(LW690 is more compatible)
1b) It has radio(flashing a radio img on a none radio phone may brick it)
1c) It uses different proprietary files
2) The MS690 uses CONFIG_TOUCHSCREEN_MCS6000=y
2a) To help with touch screen, grab the touch_mcs6000.idc file
2b) Then add the following to your .mk:
device/lge/thunderc/files/touch_mcs6000.idc:/system/lib/idc/touch_mcs6000.idc
yeah lol i realize the hardware differances.. but the kernal source contains pretty much all the source for every product, and the kernel source was updated.. im sure not all of it was updated, but the synaptics touch drivers were updated, they are not the same code as the MS690 froyo kernel source, i didnt get any errors compiling the drivers.. just got that one module error.. after my skyrim break im going to see if i can get that worked out. Also my config for the MS690 had the touchscreen listed as synaptics_i2c_rmi, not the mcs6000, but im configuring from reppards kernel, maybe ill pull the config.gz from my phone and see what it says. as always thanx again for the help.
oh, and the code you listed at the top, is that for the mk for the kernel or for the ics build?
