Root [ALPHA] ICS for Optimus M (NOW COMPILED AND BOOTING)
I need the gtalk apk.. my phone wigged out on me. And lost market. Etc... and I'm not home to get a new rom to flash it. But I'm trying to do what I can from my phone lol..
Not available door testing yet I'm having sync issues with the source.. But I believe I have everything ready to go once the source completes syncing. I've looked at bobz changes and applied what I could to the optm. Just need the ics source to test
Here is the full error I'm getting after "make" build/core/base_rules.mk:102: *** user tag detected on new module - user tags are only supported on legacy modules. Stop.
Yes, your using old modules that need to be added to the list in android_build
The ones in my example are probably the ones you need to add...the V and the M are very similar.
Ok new error with build/core/Makefile:25: Prebuilt apk found in PRODUCT_COPY_FILE device/lge/thunderc/files/apps/CarHomeGoogle.apk:system/app/CarHomeGoogle.apk try BUILD_PREBUILT instead!. Stop.
Ok new error during build. But I'm sure I'm getting closer. Error is
Make: *** no rule to make target 'out/host/linux-x86/bin/soslim', needed by out/target/product/thunderc/obj/lib/libdl.so', Stop.
soslim is part of android_build...who's android_build are you using?
I don't have that stop, so use my android_build.
I been using yours. Its not apart of the vendor? I changed everything to optimus m inside the device_base.mk. and just wondering when it builds is it using a stock kernel or oc kernel?
I have the Optimus M and am running 2.2.2. I have seen on other sites that 4.0 will be rolling out for my phone. Does anyone know when, and do you know if it will be an OTA update or something that you have to go out and look for? Any info is apprieciated. Thanks.
-Sarah
