Root [ALPHA] ICS for Optimus M (NOW COMPILED AND BOOTING)
I have the Optimus M and am running 2.2.2. I have seen on other sites that 4.0 will be rolling out for my phone. Does anyone know when, and do you know if it will be an OTA update or something that you have to go out and look for? Any info is apprieciated. Thanks.
-Sarah
Whatever you hear I wouldn't trust it. LG promised 2.3 for our phones and we have yet to receive it. Instead great developers like bobzhome, Playful God, and reppard gave us 2.3 and cyanogenmod. So once the developers you see talking here right on this thread get the bugs worked out, they will give the forum 4.0 or cm9. And no, the devs that I listed are not the only ones. Which BTW, thank you to every developer on here for what you have contributed. I appreciate your work and am more than willing to help you out with anything that I can as compensation since im broke..
Just wanted to know is it normal for it to say "no private recovery found for thunderc". It still builds I'm try it once again for MS690 build. Just wanted to know if that was normal at begging after "make". Here is my Gtalk. i will list my errors here as well but it would be easier to do chat over gtalk. regginhanger@gmail.com. i can help with what i know. so far. i am currently trying to build the source again. thanx to BobZhome for his files and help. and currently helping others start building as well. Have a Nice night everyone.
Just wondering did you have problems with the overlay>common file?
Ok after getting your dalvik this is the error that came up.
http://pastebin.com/Q0r7KyDf
So im going to try and use the original Dalvik and just add the Armv6 files to the vm>mterp>out. directory.
Yes
Yes, I had to edit out the thing that ics didn't like
New_Error_ICS - Pastebin.com
I have you idea way you got that stop
Or just try compiling as Armv5;)
Ok ill give that a try. And I noticed on some of your files on github you added # and it was giving me errors. So I had to delete them.
Thanx for taking over the trouble shooting ghost. In still having problems with the source.. Don't know what the hell is going on. Once I'm up and runnings again I'll update
I recently became the proud owner of an Optimus M that I can use for testing. =) I don't want to brick it or lose it; I still use it as a wireless device that does things for me. It is my little electronic minion, but it is available so hit me up if you want me to flash something. =) I have a 2.2, one of the older ones. It's running Bobz CM7.
has anyone got this error yet??
build/core/base_rules.mk:102: *** user tag detected on new module - user tags are only supported on legacy modules. Stop.
trying to get this going on my evo as a project...stuck at this point..and google isnt too helpful with some of these errors! lol
ok well i been. trying to figure out this error but no luck.
does anyone have the original dalvik for ICS?
So i have been reading and its something to do with the dalvik.
Ok im trying to fix the error now.. i have figured out what i have to edit and fix. :)
ok so the errors i believe i am getting is in the JNIHelp.c or the JNIhelp.h. the variable JniThrowExceptionFmt needs to be added somewhere.
If someone has the original dalvik for ics can they please gihub it. Please and thank you. For your support. Reason I ask is cause that would mean I would have to repo sync it again.
well after many days of not being able to sync past 99% with the repo, i finally have the source again. so i will be resuming where i left off and working with ghost and maybe picking bobz brain a bit to get this done. thanx for everyones patience
I wanna get my phone ported to ics. To see the new interface. Lol. It's taking awhile but it should come sooner or later
yea I want it too, but not enough to want the headache that CM n Bob etc are going thru to get it lol. Porting CM is enough for me ;)
