AndroidHogs
That's a good one tripdoc lol.
watching the screen... watching the screen.... watching the screen... my out folder is at 7.5gb.. this should be done soon lol.. not having as many errors as ghost.. i tihnk its gonna make it this time
For me, ics takes twice as long as GB to build. GB would take about 3 hours, now ics takes about 6 hours![]()
never used em at all lol.Do you use the porting tools when dealing with system.img and boot.img?
thanx man.. yeah i ahve all the images just trying to package them up.. ill load up the kitchen thanx again PGnever used em at all lol.
Just drop the system.img and boot.img into the original_update dir and select option 1 from the ./menu when u run it and the kitchen will setup a working dir for you. it will create a install-script for it, that will need to be converted to a installer-script when you do option 99 to build a zip.
Also should be no reason for you to need to use the porting tools anyhow as you compiled the system n boot.imgs for that device.![]()
