Root Am i deodoxed?
jh_husker
Member
How do I tell if I am deodoxed. I am running the. 595 GB. I am trying to load the BWC theme but it keeps force closing. Ahhhh. So confused!!!!
You probably are right and didn't flash the deodexed .595. Bouchigo has a deodex file, but I can't find it. You may wanna PM him. That should fix it, pronto. I searched for the link but came up empty.
just install over the .595 its that simple :)
To elaborate a little on what VS said, you will install it through CWR like any other zip file. Reboot will be about 3-5 minutes. After that you can install BWC; just follow the directions carefully in the first post of that thread.
Thanks alot guys. I got it to work and BWC looks great. Problem is my beautiful widgets clocks wont load. Any suggestions? ??
Edit. I just restored and tried it again and it worked. :)
