MutantCheese
Android Expert
That may be so on all accounts, but the SAMOLED is so much better. A guy can dream...
The article is quite fair and accurate in it's reporting.I wish they would have gone to SAMOLED instead of LCD on the Inc.
Well, fortunately, the touch-screen is probably the one thing that I HAVEN'T had issues with on my AMOLED version...hahaha!
I just posted in my ")(*$)(#$ I lost my phone!" thread about how I now know the difference between AMOLED and SLCD because apparently the husband rec'd an AMOLED last month, and now I have an SLCD replacement. Side by side, the difference actually is really noticeable.
I know that VZW is supposed to replace w/ the screen I had, but b/c I rec'd an emergency replacement (I was travelling), they had to give me what was in store and all that they have in store right now is SLCD.
Anyone think it's worth it for me to try and convince the online reps to exchange this for an AMOLED screen? Anyone think it will work?
The model number is on the box your phone came in right by the barcode.
ADR6300VW = AMOLED from launch day, 2GB OUTSIDE the box
ADR6300VW2 = AMOLED with 2GB IN the box
ADR6300VW3 = SLCD
(I found this at http://androidforums.com/htc-incredible/113197-amoled-vs-super-lcd-screens-5.html )
This is right but since he doesn't have the box you can check by pulling the back cover off, pull the battery out, then look at the phone where the battery was and below the Fcc logo you can see what your model number is.
Both are equally difficult to use in direct sunlight..
Or menu->settings->about phone->hardware information->hardware version
My hardware version says 0002. That doesn't reflect either 02 or 03
screen.. or am I missing something.
