Your right about the skateboards at the middle of the screen. The ones at the bottom load fine. Your turn to clarify. After all your writing and modding of your zip file. What is the md5 checksum? And what program do I need to check it? You've probably stated it more than once
Lol...
An MD5 checksum is a calculation done on a file to create a unique signature (theoretically unique to that file) that allows you ensure that its contents are complete and unaltered from the original.There's several ways to check it: with Astro File Manager you can navigate to the file, long-press the file name, select Details, and the MD5 checksum will be displayed at the bottom of the pop-up window (you might have to wait a few seconds for larger files). You can also check it using an app like AFV (Android File Verifier) [which I wrote
--its free in the Market]. Same deal: just navigate to the file to be checked, long-press the file name, and select MD5 Checksum.I'm secretly hoping that this is the issue because I'm pretty much out of ideas... You might have to start a new thread and see if we can get some other eyeballs (especially erisuser1's) looking at your problem...
Anyway, check the MD5 checksums and let me know what you find.
(since I don't really want to partition my /sdcard). I do see that the menu items are back now...
