An appropriate dp
Uh, I'm honestly not going to go there. But, if you want to google it, go ahead :o. And if the OP is talking about something completely different, I sincerely apologize. :)
I'll just let you know it's for adult viewers only. :eek:
I didn't have to Google it because I knew what you were talking about, I had to Google it because I wanted to see the results.
From my searching I've come up with.
Dew Point
Data Processing
Dynamic Positioning
The DP you were talking about
Edit: I think I found the correct answer. DP can also stand for display picture, I think the OP is wondering what would be an appropriate avatar.
Dew Point
Data Processing
Dynamic Positioning
The mystery is solved.
I suppose that a DP (avatar) consisting of a meld of the other listed DP'S would be frowned upon, eh?
I am sooooo glad someone figured this one out. I saw it as I was going to bed and couldn't come up with anything other than the first thing Dread thought of too.
Haha me too! :eek:
So, to answer the OP's question, you can set up the avatar (display picture) in the User control Panel, and I believe the limitation is something around 80x80. My last one was 80x79.... :D
In which case, the appropriate DP would be something that is meaningless until google-goggled.
Haha you guys are funny.
Yeah talking about a display picture.... sorry for calling it a DP... guess I'm stuck with Facebook terminology... my bad >_<
Oh and basically I wanted to know if it's acceptable to have a picture of yourself, or is that kinda not really done around here
Whew, that was close! :eek: Glad we got all that cleared up in a PG fashion! :p;)
Not many here use a pic of themselves as an avatar for whatever reason, but certainly some do. If that's what you want to use, I'd say go for it - you can always change it later if you change your mind.
