Just got back from VZW it's officially a brick but thankfully still under the 1 year moto warranty. Will have a new one by tomorrow.
so do they admit its their fault???
K, All Fixed. I talked to verizon and they said they didnt have ANY other reports of this isssue so they suggested a factory reset. So I backed everything up wrote down all my apps and checked the two boxes above the factory data reset, (Back up my data and Automatic restore) and did the factory data reset.
Took about 5 minutes to reset the phone but when the phone came back on the browser works perfectly.
On an interesting side note I didn't have to go through the market and re-download and re-install all my apps. It automatically re-installed all the apps I had before. I did have to re-set up my e-mail, gmail, and facebook but that was easy. Took me longer to set up my home screens than anything else.
Got 2.2 loaded and working!!! Thanks!!!
However, now I cannot connect to my Exchange Mail account at work (was working perfectly prior to upgrade). If I enable SSL, it says that I can't establish a connection to the server (SSL was enabled prior to the upgrade). If I disable SSL, it immediately returns an invalid username/password combination. (And I've typed the username and password at least 20 times. I couldn't have gotten it wrong that many times...)
Any ideas?
Thanks,
Jeff
I just want my damn battery life back. My phone is now basically unusable because it dies so fast.
When I long press the button on the earpiece, it just redials the last number. Maybe there's a compatability issue, and I have yet to try it in my car that has built in Bluetooth. We'll have to see. But for now, I am disappointed. This was probably one of the features that I was most anticipating.
I thought it wasn't working for me either, because on my previous phones i only had to press the earpiece button for voice commands. Long pressing would redial the last number like you say. I'm using a Plantronics and I can confirm the behavior quoted. A long press of the button brings up voice commands. I guess I no longer get to redial, but I can live without that as it was a hindrance more than a help for me (calling people when I really meant to turn the headset off).
Go to settings->applications->Running Services
I found lots of stuff running that I didn't need....shut off wifi, gps, etc if you aren't using it...otherwise maybe the battery has gone bad.
Hey,
I may have missed it in the large thread, so if I have, kindly redirect me and I'd appreciate it. After I downloaded the new update, I seem to have lost my playlists. They are still there, but there are no songs in them anymore. All the music can still be accessed and played as well.
Any ideas?
I have discovered that I have voice search on my phone since it was updated to 2.2. When I open it and say "send text to Ann...this is a test"
I get a screen that shows to and message. the to part is blank and the message reads "And this is a test" What am I doing wrong?
I am really hating this upgrade. I never had any problems with my phone before, but ever since the update I have had 2 main problems
1. Unable to acquire location in News and Weather App, very annoying since I like to check the weather forecast
2. Home Button does not work AT ALL. This is a huge problem for me. The only way to get back to the home screen is to continuously press the back button
I have read that a factory reset will sometimes fix issues with froyo, but I really do not want to do this. I don't have the time to renter all my contacts and configure all my settings.
Is there another fix? Is there any way to downgrade to 2.1 until this release is less buggy?
Thanks!
I got my Froyo update this morning and I just now realized that I have a similar problem. I'm using the standard music player and now it's not recognizing the artists/albums. They all show up as separate playlists or under songs.
Anybody else have this issue? Is this something that will get cleared up with the second update?
