slimjim1814
I have been running mp4 video on my droid since day 1 back in November and since the 2.2 upgrade, I can no longer play the video's that played fine on 2.1. I get audio, but the video hangs on one frame and doesn't play at all. I can skip fwd and the frame changes, but will not 'play' the video.
My video is encoded (using BeyondTV's H.264 codec) at either 640x480(SD) or 848x480(HD) @1200kbps and aac 48khz 160kbps. All videos played quite nicely on both the internal video player and Act 1 video player before the 2.2 upgrade.
I downoaded Rockplayer to see how it would handle the videos, and the audio is fine, but the video runs at about half speed, so it is not acceptable either.
I haven't heard of anyone else with this problem. Help?
Many Thanks!
I had the same problem with my videos. All of them played just fine with 2.1, with 2.2 some just displayed a black box instead of a thumbnail some looked like and played like a vcr tape being fast forwarded. It was a mess.
I downloaded Daniusoft Video converter, it has settings for the Droid already in it, and just reconverted them all. Now it's back to normal.
The video was really the only problem. The battery seemed to drain more but I got rid of TasKiller and installed Task manager well see how that goes.
