colchiro
Extreme Android User
cmtouchpad - Android port for HP Touchpad - Google Project Hosting
Issues - cmtouchpad - Android port for HP Touchpad - Google Project Hosting
A new bug has been found... airplane mode: issue 28 (Air Plane mode sticks) reported by daling...@gmail.com
I hope they get the airplane mode fixed. The Nook Color has the same problem and if you turn on airplane mode, then turn it off, it stays on after a reboot. They had a fix for it a couple times, but then backed out last minute.
So if you turn on airplane mode, even for just a second, every time you reboot you have to turn wireless on again. It takes an adb command to fix it by deleting the entry in a database.
O/W I read BlueTooth support is finished.
