novox77
Leeeroy Jennnkinnns!
I decided to rename HtcLockscreen.*, which effectively disables the Sense lock screen, and the phone defaults to the Android lock screen, which IMO looks a lot better and provides more function and information.
This morning, I discovered the downside of doing so. I had no way to shut of my morning alarm, which is set with the Sense clock app/widget. Normally, the alarm app communicates with the lock screen to give me an option to snooze/dismiss via the lock screen. But evidently, the alarm doesn't know how to communicate with the android lock screen.
So the only way I could figure out how to silence the phone was to power it down. I ended up downloading an alarm clock app, and I'm now using that instead of the Sense alarm. Everything is good again.
I was just wondering if anyone had a more elegant solution to this problem. I will not consider lockscreen apps like WidgetLocker.
