A
akkkmed
Guest
At this next step, it shows the #, so that's fine. But after each command, it says it's a "read-only file system". I continued on anyways. But then here: "- chmod 4755 /system/bin/su", it says "unable to chmod (blah blah): No such file or directory"
- mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
- cp /sdcard/Superuser.apk /system/app/Superuser.apk
- cp /sdcard/su /system/bin/su
- cp /sdcard/busybox /system/bin/busybox
- chmod 4755 /system/bin/busybox
- mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
- exit
- exit
- exit
- exit
then you can install the zip from Fabs thread on page three in clockworkmod recovery
