You would flash the MR1 RUU, to go back a step. Not in performance necessarily but back to the official OTA.
Depending on how the new update differs from MR2 you may not even get an OTA notification.
The official update will be leaked prior to being pushed, so I'm not sure why you would go back, but you certainly could.
But I can install future OTA's with the MR2 update installed?
The short answer is NO. You will not be able to install OTA's without having the current software version that is official from Verizon... the OTA check the software version before installing...
But you will be able to flash the RUU of the OTA once it's available - wiping your phone.
I went throught that BS when I had my Eris, so that's why I've avoided installing leaks. However, if you want to root... you don't have to worry about OTA's
Ok, so where can I dl the MR1 ruu to reflash?
I recently had to do it with my tbolt, although I was rooted, and haven't had an android phone that wasn't rooted within a week or so of owning it so ill take your word for it.
Just seems the phone wouldn't know it's being downgraded, but then again theory and practice are 2 different things.
That's the problem with rooting to begin with. The phone starts owning you, not you owning the phone.
